Question about Refrigerators
Jenn-air side by side refrigerater
Freezer works great but refrigerater runs all time but does not cool. control set on high
  • Anonymous May 12, 2009
    I have the same problem with a GE. Fan is not running how can I test power to fan. I replaced the fan motor already but no success.
  • 150 Answers
Make sure the fan is working ,its located behind the freezers back wall.(5 to 7 screws) If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it w/ doors open 12 to 24 hrs this will free up any clogged tubes.Turn it to 4 or 5. Good luck.Let me know.
Len West
Posted on Feb 21, 2009
Freezer keeps cumulating ice and does not cool fridge part of refrigerater
sounds like the adaptive defrost control. this has happened to me 2x's so far. each time there was a clattering kind of sound that came from the frig. you can get this part at repairclinic dot com for about $70. only takes two tools to replace it; philips screw driver and 1/4" socket. it is located in the frig in the back right corner of the plastic housing around the temp control sliders.
Oct 07, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Jenn-Air side by side Model #JCD2389DES. We noticed freezer was only doing a soft freeze..we removed several items which we thought were blocking vents in freezer...next we noticed refrigerator side was...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 28, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer, and refrig not cooling....ice maker stopped working too.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
tygjcn
Jul 09, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air JCD2389GT and it is not cooling correctly. It is on with settings in the middle. Why is it not cooling?
heatman101
yt785
Jan 07, 2010 | Jenn-Air JCD2389G Side by Side...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
My Jenn Air JCB2285HES not cool on both sides not frozen line
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Freezer works, refrigerator isn't
If your refrigerater is cooling correctly it should be in the zero to ten degree range.If this is so then you must have an airflow problem from the freezer to frig compartment. Check your airflow control setting to verify it is in middle position.Next check vent with your hand ,you should feel cool air coming through.Note that side/side frigs have one at the bottom too.Hope this helps
Jul 30, 2009 | Frigidaire Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
