Question about RCA RCR311B Remote Control
Remote not working properly
The remote has 3 fan settings, the lowest setting does not work at all, the middle setting activates the low speed, the top fan speed works, so I have no middle speed fan (which is the one I use most).
Hunter Remote RF110-2-7
SOURCE: rca 3 in `1 universal remote
press tv button and hold it down, While holding down tv button put in code (for Quasar tv: 1054), light will go off then back on when code is entered, release tv button and now remote should be programed
Posted on Jan 28, 2008
  • 1124 Answers
SOURCE: RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Posted on Oct 12, 2008
  • 231 Answers
TV Can Not Be Programmed on this remote. Sorry.
Posted on Dec 24, 2008
  • 814 Answers
SOURCE: cannot program new phillips remote to rca tv
[*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Posted on Jun 19, 2009
SOURCE: Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
Posted on Aug 22, 2009
Kendal fan/light remote UC7208T doesn't dim
If you have CFL bulbs they won't dim. There should be a switch to change remote from CFL to incandesant light inside the transmitter. You'll have to match settings with settings in receiver.
Nov 25, 2013 | Dryers
Remote control is not functioning properly. Will turn on, using "high speed" button, but then drops to "low speed' wil no rmain on 'High speed"
the receiver in the fan is going out, they do all the time with remote set ups, also remember that if the fan has been wired through a wall switch,, this will hinder the remote from working properly
Jul 08, 2011 | Hunter 22435 Sontera Antique Brass Ceiling...
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Hunter 52'' fan worked one morning not in afternoon?
try this. always start your fan on high. always. then set it to the speed you want. the flashing lights are, of course , telling you something. you need the owners manual. even if lowes dont sell that particular brand, they can help you find the info. you need.
Apr 04, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan speed too fast
Is there a light switch control or just straight power to the fan? They do sell "Fan" controll switches just like a regular dimmer, but for a fan. If there is just straight power u would still be able to install a remote that could lessen the speed. Even if it is just pull chains. the remote would have three speeds and if u kept the pull chain on low, maybe the low remote speed could work.
May 22, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
RCA RCR311B Remote Control Logo
116 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
