Question about Epson Stylus C84 InkJet Printer
Not printing I just bought the EPSON STYLUS C84. it is not printing. why? it runns paper threw it just no ink goes on paper.
  • Epson Master
  • 419 Answers
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Posted on Feb 21, 2009
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 prints, but there's no ink on the paper
This might sound stupid, but did you remove the plastic film that covers the head?
Try this, if still nothing happens, go through your printer settings and run a "Cleaning" cycle on it.
Aug 28, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Hi
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Ink refill
You can do a search on Google using "Epson C84 Refill Instructions" which will produce plenty of hits. However, this one gives very clear instructions:
http://www.refillinkcartridges.co.uk/news/2008/10/16/epson-c84-ink-cartridge-refill-instructions/
If you only bought refill ink rather than a refill kit, and don't have rubber plugs, you can successfuly re-seal the filling hole using a small amount of epoxy resin e.g. araldite. This is easy to remove with a sharp knife the next time you want to fill it. Note the need for a cartridge re-setting tool - these can be purchased very cheaply on E-Bay.
Apr 07, 2009 | Epson Stylus C84 InkJet Printer
Epson stylus c84 inkjet printer
I don't know if this will help but your problem sounds like one I had with a C82 model. On the right side of the printer below where the print head rests is a small plastic suction tube. This tube can become disconnected and will prevent the printer from printing. Check to see if this is your problem. In the picture the red circle shows where the tube connects and the yellow shows the tube.
Jul 13, 2008 | Epson Stylus C84 InkJet Printer
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Does not print on paper but with new ink replaced
proably is the nozzle in printhead clogged by dry ink because you dont use genuine ink from epson and i suggest a replacement of the head because it is almost impossible to clean it out
Mar 02, 2008 | Epson Stylus C84 InkJet Printer
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
75 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
