Question about Cyber Acoustics 3-in-1 Headset/Mic Headset
HS 600 cyber acoustics mic isnt working...
I dont have it set to mute or anything like that. it jut wont work on skype or world of warcraft or anything else for that matter....
  • Anonymous Mar 09, 2009
    I have the same problem
  • aznboy124204 Mar 25, 2009
    i just can't get the mic to work
    Problem Solver:
  • 5 Answers
The issue lies in the glass fiber wire, the wire is coated with a conductive metal only a fe mircons thick.
Simply put the headset is a poor production model, the use of glass fiber wire more often than not results in a short in the wiring. Thus the sound will come out of one side, not at all, etc.
Posted on Jun 15, 2009
I have just set up skype on my laptop and tried using the echo /sound test. Though my mic seems to be working I do no hear anything. I have checked the sound settings and skype does play sounds through my...
If you are running Windows 7 you can have audio set up to listen to the mic. I would not recommend this though as there is a slight delay from you talking to it coming out of the headphone. This can cause you to stumble on your words. But solely for testing purposes do this if you use Windows 7:
1. RIght click on the speaker icon in the lower right corner of your display and select recording devices.
2. Make sure the microphone you use is highlighted blue then click properties button in lower right corner of the window.
3. Click on the listen tab, then check the box that says listen to this device.wdaexodus.png
Mar 05, 2011 | Cyber Acoustics AC-201 Consumer Headset
People can only here me faintly at the other end
If you bought a webcam, dont assume it has a microphone built in, not all of them do.. if you do have one, then make sure it isnt muted (double clicking the speaker in the system tray next to your clock, and make sure the mic isnt muted, if it isnt and you still have no sound, the microphone header on your motherboard may be connected incorectly or not at all, if you are plugging the microphone into the front of the PC, take it out and use the pink plug at the back (one one labelled with a picture of a microphone).
Check your sound preferences by double clicking the speaker icon in the corner of the monitor first. Make sure it's working there, it's in the Input Tab. Then when you are sure it's working there, go into Skype preferences and change your mic input to the appropriate mic input, and then use the Test Call to check your microphone settings to see if they work, if you hear yourself then others will be able to hear you.
Thank you!
May 18, 2010 | Skype IM
My mic on my headphones doesn't work. Nothing is muted.
If headphones mic doesn't work on different PCs then the problem with headphones set. There are 2 possible problems: broken cord or bad microphone. I think this is cord problem and unfortunately don't know the way to test it at home.
I think replacing the cord will resolve the problem. Source(s): dont forget to rate me.... Good Luck.....
Apr 06, 2010 | Cyber Acoustics AC-201 Consumer Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
My laptop is not recognising my microphone. The mixer does not even have a ''mute/unmute'' option and the volume control my mic isnt even there. in my sound/audio devices, for voice recording the advanced...
make sure the mic jack is not in the speaker jack please try swap it. if it does not work, plug the mic and go to control panel select sound devices there u can set ur mic, if not reinstall ur sound driver, thanks, dont forget to vote me if it works
Jul 18, 2009 | Computers & Internet
My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Cyber acoustic headsets
make sure that your mic is ot muted cause thats what happened to me also check it when ur done in your audio manager
May 26, 2008 | Cyber Acoustics AC-201 Consumer Headset
Cyber acoustic mc 1060
For Vista 32 bit. Go to the driver manager. De-instal/delete the driver in the Sound, Video and Game section. In my case it was RealTek High Def Audio ver (Select Delete the driver files.) Reboot. Vista will reinstall a driver. In my case it was Microsoft High Def audio ver 6.0.6000.16386. I had the mic plugged in when I rebooted to load the new driver. The Cyber Acoustics ML-1060 now works fine. Hope this helps.
Jan 25, 2008 | Cyber Acoustics CV-1064 Microphone
Does not work on Skype and Messenger
In Vista, right click on the speaker icon in your system tray (usually located at the bottom right of the screen) and select "Recording Devices". Be sure that your microphone is enabled in this list. In Skype and MSN, find the audio hardware setup, and make sure to select your mic-in port into which the mic is plugged.
Dec 12, 2007 | Cyber Acoustics CV-1064 Microphone
Cyber Acoustics 3-in-1 Headset/Mic Headset Logo
552 people viewed this question
Top Cyber Acoustics Radio Communications Experts
Mike Charette
Are you a Cyber Acoustics Radio Communication Expert? Answer questions, earn points and help others
