Question about Archos AV 500 400-Hours Video Recorder
No power whatsoever to my Archos 504
I'm having problems with my Archos 504 MP3 player. I had a file corrupted message on my screen and after I turned the machine off it was unable to power up either with the docking station or with the computer connector. I bought a new battery and still have no power. I have over 15,000 songs on it and I don''t want to buy a new player. What can I do?
There is little documentation regarding the reset. However there is one in the Archos 504. If you take the battery off and look at the connecting Pins of the battery of the main unit. You will see a small Gold Button (looks like the circuit). This is the main reset button. If you Press it all will be good. You will not loose anything unless you have a Main File corrept but at least you will get function back so you can fix the firm ware.
I hope this helps you.
Ed
Posted on Mar 02, 2009
  • edj0527 Mar 02, 2009
    Let me clarify. It will be to the right of the battery pins and down towards the middle of the space between the edge of the unit and the base of the battery if your holding the unit in your right hand with the pins at the Top....
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
I am having archos 504..It only plays windows media player files if I want to plar other player files how can I do that?
get the best all round anything player KMPlayer. link below..
kmplayer.en.softonic.com/ - United States
Mar 05, 2010 | Archos 504 500870 Digital Media Player
Archos 504 hard drive upgrade
  • go to archos.com
  • go to support and account near top of your screen and go to downloads
  • the archos website should tell you what to do next
Oct 06, 2009 | Archos 504 500870 Digital Media Player
I can't play video on my Archos 504
This problem seems to occur when the device overheats. It doesn't make a whole lot of sense, but most videos set at 720 by 480 wont play when the device is left running for a long period of time. The smaller video files, however, still play. I think it deals with the amount of system resources required for such files to play. If you turn the device off completely by going to menu, power, and turn off device, and leave it sit for 30 minutes, all files should play properly when you turn it back on.
As a suggestion, DO NOT leave your Archos powered on and on the dvr station. This causes the device to constantly run, and if you havent noticed the Archos operates at an extremely high temperature.
Also try the reset button just as a back up to what i have put. Karlos
Jul 04, 2009 | Archos 504 500870 Digital Media Player
504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Sep 08, 2008 | Archos 504 500870 Digital Media Player
Archos 504 huge problem
I had the same problem. I droped mine and it seems to have messed up my hard drive. i replaced it today and my comp. can now reconize it. i have been trying to contact tech. support to see if it is possible to get the OS back on the PMP. if the Tech support ever picks up my call i will message back with the fix.
Aug 02, 2008 | Archos 504 500870 Digital Media Player
Archos not booting up - coming on
Kept trying the reset and just before I put a hammer through the hard drive it started again. Yippee!
Apr 04, 2008 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Placing films onto the 504
I have put plenty of DVDs onto my Archos, but I use the optional cradle which connect to the TV as well as DVD players. You simply connect the DVD player onto it and play your dvd, which switching on the Recorder function on your unit.
Alternatively, can you convert the DVD onto your PC and then transfer onto the Archos in normal fashion, or is this what you are saying you tried to do already?
Sep 14, 2007 | Archos 504 500870 Digital Media Player
Archos AV 500 400-Hours Video Recorder Logo
345 people viewed this question
Top Archos Televison & Video Experts
Henry  Thomas
Henry Thomas
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
