Question about Maytag Performa PAV2200
Performa washing machine not spinning
My washing machine does everything but spin. can anyone help
    Problem Solver:
  • 14 Answers
Take the back panel off and turn the wash on and check if the belt isnt spinning or the motor
Posted on Feb 21, 2009
Maytag performa washer noise
sounds like the bearing on the drum is noisy or you have some small change between the drum and the casing
Apr 27, 2012 | Maytag Washing Machines
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
you will most probably find that the inside of the belt that runs on the pulley has been breaking away bit by bit and if the pulley stops where there is a bit missing it may not turn when the pulley starts to turn.
Just a thought as it has happened to me a few times
The odor is most probably burning rubber as the pulley spins on the belt
May 26, 2009 | Maytag Performa PAV2200
My MayTag performa oversized capacity washer wont spin
Usually this is caused by the pump being cloged or broken. Remove the pump and clean the pump out. Make sure it spins freely by hand.
Nov 20, 2008 | Washing Machines
Maytag machine not spinning
You have a stuck brake.My advice is leaving this one alone and lrt a tech. fix it.HINT:99% of this same problems your having I have fixed without replacing 1 part,so see if your repairman can do the same.This is a PERFORMA and is know way Maytags design.Except one thing ,the name on the front panel.
May 31, 2008 | Maytag Performa PAV2200
Washing Machines Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
