Question about Mtd 22" Yard Machine Push Mower
Toro 826LE snowblower...impeller engages only randomly
I have an 826 LE Toro snowblower. When I engage the auger drive, nothing happens. When the snowblower is in this condition, I can spin the impeller, but the augers do not turn. I had the same problem earlier tonight...I took the belt housing cover off, and really did not do anything (did not change belt, etc)...I put the belt housing cover back on, and then fired it up. The impeller/auger then worked as normal. I snowblowed the driveway, then the issue happened again. I can free spin the impeller without the auger drives turning. Both shear pins in the augers are good. What seems weird is that I can grab the impeller and pull it back and forth from the back to the front of the machine...this seems odd.
Do I have a minor problem, or is this the sign of the gearbox giving up the ghost? Why would this issue seem intermittent in nature?
Any help you can give would be greatly appreciated!
  • NewHondaLove Feb 21, 2009
    Thank you very much for the posting.
    One additional piece of info. There should be 2 shear pins/bolts that hold the impeller onto the shaft that goes to the gear box. I no longer have those bolts there...I guess they broke...I tried to put another bolt in there, but it will not go. I am not sure if there is a piece of the former bolt stuck or what.
    I actually went to a parts shop today and they pointed out that they believe the problem to be the "helical gear". Is this the worm gear that you mentioned?
    Thanks!
  • NewHondaLove Feb 22, 2009
    As I had suspected, once I installed a shear pin (bolt) into the hole that attaches the inpeller to the shaft, it works like a charm!
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Posted on Jan 10, 2009
  • 246 Answers
SOURCE: mtd snowblower 4.5 no spark new coil,new plug
Hello pbck98:
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
>>If you have a New Coil/Ign Coil and Still No Spark, then
>>Turn the Coil Over and Check for Spark. Ign Coils are Wound 1 Way for Clockwise Engine and the Oposite Way for Counter Clockwise Rotation Engines. I have Seen Ign Coil Boxed Wrong and Turning the Ign Coil Over will Correct the Problem.
>>The Coil is Gapped to .015in from the Flywheel.
For Better Assistance;
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
SOURCE: my yardmachine snowblower won't stay running. It
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Posted on Feb 10, 2010
heatman101
  • 43501 Answers
SOURCE: My Yard Machines snow blower
The bearing can be a bugger to remove....and it sounds like the bearing may also be bad... so you will want to replace that also...
To get it off make sure that the set screw(s) are backed out with an allen wrench...the set screws will be in a small hole in the lip of the bearing....an allen wrench is a six sides wrench that comes in many sizes... the screws may also be a metric size...
then to remove the bearing you will need to use a gear puller that will grab the bearing equally with thre jaws and the use the shaft for leverage as you turn the screw to pull the bearing off of the shaft...
You will bugger up the shaft if you keep trying without the proper tools and then you will really have a mess on your hands...
heatman101
Posted on Dec 21, 2010
  • 144 Answers
SOURCE: My MTD 10hp auger will
Yes there are 2 belts one for the drive and one for the auger. If you remove the cover on top that is located between the engine and the auger housing you can check the belts. The auger belt has come off the pulley or is broken. Hope this helps you out. Best regards and good luck.
Posted on Jan 09, 2011
Toro 826le snowblowAuger driveshaft moves excessively.Auger drive pulley moves excessively. Suspect bearing failed. Is this a do it yourself job or a PITA job that is worth paying someone else to do?
Hi Peter:
Sounds as if you've a pretty good idea of what is wrong.
Your own comfort level will determine whether or not you want to attempt the repair.
Personally (as a frugal do-ti myselfer) I tend to explore the problem and determine how complicated the fix will be. Then there is the matter of whether special tools are required, and just how involved the fix will be.
Rivets can be replaced with bolts, damaged metal can be welded, ingenuity can triumph over adversity. (Didn't that sound profound?)
On with the day!
Feb 29, 2016 | Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Feb 11, 2015 | Mtd Garden
Pull starter won't pull
ALL-- Power Equipment-- needs to be inside & warm,
NOT in an outside shed
Have to warm it up inside-neighbors garage!
Feb 28, 2014 | Toro Power Max 726 OE Snowblower - 37771
Fix ariens snowblower 520 dies when engaging the auger lever
Your front end is jammed. Its either frozen or there is a rock or something jamming it up. Before you start engine reach down chute and turn back impeller that throws the snow out of blower. Should turn freely. when its free its fixed. You will probably need a new belt.
Feb 17, 2014 | Garden
Vibration when auger is engaged in Toro 726 oe
be sure to check pulleys for a rock or anything else lodged in there
then check rear bearing for alot of play up and down
Feb 08, 2014 | Toro Power Max 726 OE Snowblower - 37771
I have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
Mtd 22" Yard Machine Push Mower Logo
1,324 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
