Question about Sharp Viewcam VL-AH60U Hi-8 Analog Camcorder
8mm Cassette mechanism fails to eject or sometimes fails to close
Started having cassette jam problems. Battery is fully charged. Tried different "Hi 8"cassettes but no luck. Unit fails to eject cassette after opening the compartment door. If the cassette does eject after attempting many door opening and closing actions then the ejector mechanism stays open and will not retract after inserting another cassette. I have never forced a cassette into the loading mechanism. The unit has always worked very well until this recent problem. What can I possibly do to remedy this situation? Our local repair center charges $70 just to estimate what, if any, repair may be required. Your assistance with this will be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
Maybe some dust lodged in there.
Posted on Apr 09, 2017
  • Sharp Master
  • 13,192 Answers
I would try cleaning out the unit with air in a can. maybe some dust lodged in there.
Posted on Apr 05, 2017
  • Sharp Master
  • 5,412 Answers
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
philipp
  • 217 Answers
SOURCE: Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Sep 28, 2007
  • 64 Answers
SOURCE: Sharp camcorder vl-wd450
something is wrong with the m-chassis needs repair sorry the chassis on any cameras are very sensitive and they break alot not yor fault.
Posted on Nov 19, 2007
  • 24 Answers
SOURCE: Sharp Viewcam VL-AH151 Hi-8
Camcorders have a sensor, often a small manual bumper, to detect if the write-protect tab is engaged or not. It sure sounds like yours is damaged, preventing the detection of a writeable tape. Check to make sure there's nothing obstructing it (obviously, it'll be near where the copy protect tab goes when the camcorder is closed).
Posted on Jan 21, 2008
QTipsX800Pro
  • 48 Answers
SOURCE: My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Posted on Feb 19, 2008
otacon
  • 1944 Answers
SOURCE: Sharp video camera VL-AH50
Did you try cleaning the tape head?
Posted on Feb 22, 2008
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 400 Mini DV Digital Camcorder
Cassette Jam
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Sharp Viewcam VL-AH60U Hi-8 Analog Camcorder Logo
97 people viewed this question
Top Sharp Video Cameras Experts
Larry Stiles
Larry Stiles
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
