Question about Canon PIXMA MP600 all-In-One InkJet Printer
I'm getting error U043 on my Canon MP600. I think I understand the fixes I have read online here. My question is why can't I scan when there is a print problem?
  • 10,515 Answers
Already posted on Fixya.
http://www.fixya.com/support/t319660-mp500_ink_tank_cannot_recognized_error
Its for mp 500, but would work for mp 600.
Thanks.
Posted on Feb 21, 2009
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Ink Monitoring System
I have this Canon MP600 using unchipped cartridges. Once you have changed the chip over onto the catridge and inseted it should stop flashing which indicates the cartridge is located. The printer will not tell you the level of ink until you run out. When changing the chip over from original cartridge onto unchipped ensure it is not damaged and fitting properly other wise the error sign will show.The printer should print without any problems, i know you can not disable the ink monitoring system. Hope this is some help Mr T
Apr 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 error code U043
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP500 ink tank cannot be recognized error U043
I had the same problem. My mp630 is also only 4 months old. I replaced all colour ink cartrdiges(inc black), but was only able to release the function for detecting the ink levels for magenta and cyan. Yellow and black then started giving error message U043, with them alternating between working, but never working at the same time. Getting them all clicked in with the lights glowing red does not solve the problem, as once the printer cover is closed, the same error message turns up. The only thing that worked for me is moving the chip slightly out of alignment, by pushing the sliding chip holder, and I only had to do this twice before they all started working and the printer was unlocked.
Jul 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Same problem - two solutions I found helped me work out mine. One said contacts needed to be cleaned and it worked to use a Q-tip and alcohol or just click it in position several times until it recognizes the cartridge - this may work. Another said that they got it to work by installing a brand new cartridge - cool, but I have one full of ink it won't recognize. So I pulled the little circuit board off a used cartridge (like you need to do with some refills) and put it on the cartridge that it wouldn't recogrnize - works great. Still haven't figured out how to get it to acknowledge ink levels though. Canon really should be more consumer friendly since these problems seem to be intended to compel the use of proprietary cartridges.
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Sep 17, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
655 people viewed this question
old marine
old marine
