Question about EliteGroup P4VMM2 Motherboard
Controll panel connectors - EliteGroup P4VMM2 Motherboard
  • borney May 11, 2010
    Can you tell me what do you mean by control panel connectors?
    if you were asking the onboard connectros or what device goes to wich connector please answer.
    Best regards borney.
  • Michael Thomas
    Michael Thomas May 11, 2010
    hi there :
    hey can you give me some morre infor on this problem i think i can help i just need so me more info on exactly what is going on or what you are wanting.
    best regards mike
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Here you go.
Posted on Sep 03, 2009
Mic not detected
You probably installed the MIC into the wrong connector. Please, verify your mic is on correct/right connector, check you have audio before.
If you don't have audio, install the correct drivers for it.
After you do that, you need to go to audio panel, for that use:
Windows KEY + R, then type: control /name Microsoft.Sound
And now press ENTER/RETURN.
Good luck.
Mar 29, 2014 | Computers & Internet
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
775 audio conection are fine but no sound from front panel
You need to go in the Sound setting control panel and disable the sensing - or enable the front connectors permanently, depending on what sound chip you have.
Jun 21, 2011 | Computers & Internet
ASUS Motherboard AT5IONT-I, Win7pro,4G RAM,SSD. Everything works fine with a screen plugged into the DVI connector. HDMI output does not recognize any screen, tried everything, installed latest Nvidia...
i have the same problem!
AT5IONT-I, Win7pro,4G, bios 0502
tried many screens, nvidia driver versions etc.
hdmi only works in single monitor configuration. hdmi blanks on detection of dvi monitor. argh!
Apr 18, 2011 | ASUS Motherboard AT5IONT-I Atom D525 ION...
Control panel connector pinout for Dell Dimension 1100
Well the official Dell manual can be found on their website here. I don't know if this helps or not, but I hope it does! :)
Feb 17, 2010 | Dell Computers & Internet
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Front panel connectors/jacks is not working
OK--usually what you will find from the front is 3 connectors.
One will be a solid block that has one blank hole which is the key. That will plug into the corresponding pins on the motherboard--usually toward the back of the case.
There will be another other wire that terminates in two plastic connectors. These are the USB connectors. Sometimes the connectors are in two parts. One is a 3-hole and one is a 1-hole. Usually you will find two sets as they sort of go together.
The pin configuration on the motherboard looks like this ::::.
The single pin on the end is not used. The other ones are connected with the plastic connector on the first three starting at the left, with the end marked VCC to the left. The fourth pin is the ground which is usually the separate connector.
The second USB connectors are plugged in right next to the first--so each block of pins controls 2 USB ports.
Hope this helps.
May 14, 2009 | ASUS Computers & Internet
Fr.and rear MIC and h-phones connectors work simultaneously?
there may be an option in your audio dievice manager to treat "microphone jacks as seperate input sources. if your software does not support this, then you will have to get another soundgard
Apr 23, 2009 | Abit NF7-S V2 Motherboard
Fpanel
Hi, the most common case colored wires used for negative - is white. The colors blue, red, green are usually positive +. The internal speaker though it uses a 4 pin connector only plugs onto the 2 end pins. Black is connected to negative - pin & Red is connected to + positive pin. Go to page 1-26 & zoom in. The case's connectors should be marked closely like the on-line manual. All these case LED's use 5volts DC. If you make a boo-boo (place the connector on back-wards, don't freak out). You can usually shut down the system & turn the connector 180 & re-connect it with out hurting the board. I know it’s a tight fit, so start with the power switch & test it once connected.
You should be just fine.
Good luck unreal_class!
Mike
Sep 09, 2008 | ASUS K8V-MX Motherboard
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
206 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
