Question about Sony Playstation 3 (PS3) Console
Ps3 does not appear menu screen & AVI cable trouble
My PS3 can read and play game well. But when I exit the game to come back menu screen, it appears nothing. Also, since the time I change to HDMI cable, I cannot connect Ps3 using avi cable again, what's wrong ??? Pls help me
    President:
  • 2,653 Answers
To fix the HDMI AV cable issue just do a manual video reset. When you power on the PS3 hold down the power button until you hear two beeps then quickly remove. If you have other problems I would suggest doing a System Restore under Settings.
Posted on Feb 21, 2009
No communication between PS3 and TV
try geting a new hdmi cable or a new av cable and plug it in turn on the ps3 let it sit turned on for a while and a message should pop up saying it has found a hdmi or av output witch ever you are using and it will ask you if you want to use it as the ouput to the tv and then you will select yes. if that dident work your gpu (graphics processing unit) has over heated and you will have to send it to sony or take it apart and reflow the prosesers and gpu
Jan 01, 2013 | Sony Playstation 3 (PS3) Console
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Hi, My ps3 used to play avi files and now whichever one i use it ownt play( eve if it played it previously) its pauses and a small clock appears in the bottom left hand side of the screen. I dont...
1) Reset the settings on the PlayStation 3 by having the unit turned off, then pressing and holding the power button on the front of the unit until you hear it beep twice (shouldn't take more than 7-10 seconds), then release. All of your settings will be reset to the factory defaults, and you can make adjustments as needed.
2) if you are streaming the avi files from a media center via wifi it is more than likely a connection error try hooking up your ps3 directly with an ethernet cable to your router if possible this should fix the problem
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
My ps3 has a problem reading all disks i put in, the spinning icon appears at the top right of the screen but nothing happens, this also happened when I tried playing a demo I downloaded
If your Ps3 has trouble reading all discs, then the lens could hardly read them due to it being dirty. Try to use a disc cleaner and let it spin for like 30 seconds. If this does not work, you need to manually clean the lens opening the casing and removing the screws covering the lens. Get a cotton swab and damp it to an alcohol. Gently wipe the lens' surface and let it dry. Then return everything back and try playing those dics again.
Please let me know how this goes. Thank you for using FixYa.
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont read discs
your blue ray player is broken you have to send it back to sony if you have warrenty its free but if you dont its $150
Apr 01, 2010 | Sony Playstation 3 (PS3) Console
Ps3 not reading discs!
what is wrong is when you got the blue ray set up it was probly set up diff.if it is not reading games or movies then you eye is scrached.the eye if u dont know is what reads everything
May 27, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
My PS3 is stuck in set up mode and I can't exit to play Rockband?
shut PS3 off with the back of PS3 switch then turn it back on.
Dec 24, 2008 | Sony Playstation 3 (PS3) Console
Fixing BD movie disk on UK Ps3
Try a Blue Ray lense cleaner dont where to get
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
TV Screen Flashes
Hello!
As always, I suggest you get some canned air and blast it out from the front and sides. Just use the air holes that are on the machine. That way all of the dust build up can exit in the back. Also, check all your cables and revert back to your manual. Something on your TV stand may be interfering. If all else fails, then call Sony and get a box sent to pick up your PS3. I'm seriously out of ideas on this one. I hope this helps!! Good luck.
Aug 07, 2008 | Sony PlayStation 3 40GB System
Sony Playstation 3 (PS3) Console Logo
200 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
