I am using my g link cdma1x modeam to connect to internet.it uses ruim card.i have instelled g link modeam software and i can connect through my internet..but my problem is that i cannot call,check my sms by cdma modeam software.the problem is that when i try to call..it appears as "window has encountered problem" and software stopes..plz send its remeady
  • BP Sir Mar 15, 2009
    My glink cdma 1x modem is not working with vista 64 operating system, how can i solve this keeping my computer the same operating system?
  • mirageNP Apr 05, 2009
    i cannot call,check my sms by cdma modeam software.the problem is that when i try to call..it appears as "window has encountered problem" and software stops with the error "HICard.exe"
5 Suggested Answers
  • 6 Answers
SOURCE: sms sending failed
soft ware is not corrupt it is a miner problum.
there is messege setting
u will c there other setting
there is sms center no.
u miss that no.
wich coumpani cell u used all companies have different no of sms center ok
put the currect no
Posted on Mar 13, 2008
  • 111 Answers
SOURCE: my modem does not install in window vista
Hi, simply all you need to do is download the vista driver for your modem. Here is the link: http://www.dlink.com.au/tech/Download/download.aspx?product=DU-562M&revision=REV_A&filetype=Drivers
just download the driver for vista 32bit and unpac and install it.
Hope this helps.
Please vote if it does. Thanks.
Posted on Apr 18, 2008
krohiti
  • 78 Answers
SOURCE: My modem does not install in window vista
hi, This is rohit from Primus Tech Support, Canada
As i understand correctly, you canot make the modem work with windows vista, right?
Make sure that the OS Window Vista has not encountered any problems while installation process.
Try to create a conectoid
click start>control panel>internet connection>network and sharing center>setup a new connection or network>connect to the internt>broadband PPPoE> Enter you User ID and the Password (contact your ISP) confirm the password and click connect.
You should be conected.
Make sure the ADSL LINK or DSL light on the modem is solid before you create the connectoid.
Regards,
Rohit Singh
Posted on Sep 24, 2008
pongta_rajku
  • 55 Answers
SOURCE: PC not detect and software not to use
change the software and check the modem again
Posted on Apr 09, 2009
mashoodh
  • 69 Answers
SOURCE: can i use rim sim card & gsm sim card in only one phone...
you can cdma sim use only in rim programmed mobilephones,can not use all gsm mobilephones
Posted on Apr 18, 2009
Computer will not connect to the internet
This happens often to my wireless router. I just unplug it and plug it back in again. That has worked for me many times
Nov 17, 2012 | E-Machines eMachines Desktop PC
I wnt instel my cam software by net but nt succes to instel that
You must find the correct software on the internet. Google your webcam model and make and download the correct software to install it.
Mar 03, 2011 | Computers & Internet
I M A TATA INDICOM CDMA,USER UNABLE TO USE INTERNET ON SAMSUNG SCH- M 369 M power, WHILE CONNECTING IT SAYS "UPGRADE YOUR RUIM TO OBTAIN DATA SERVICES",PLS HELP HOW TO SOLVE
CDMA M-369 is a bad phone. this phone is unable to use internet. i suggest everybody dont buy this phone. VERY BAD PHONE.
Jan 03, 2011 | Samsung Cell Phones
I have Haier HC-C2030 phone came with TATA INDICOM. Due to low battery it switched off automatically and when I charged it and switched it on, It is showing "Please insert RUIM card". I am unable to...
Hello , Ankit
you must reinstall the system software through the dealer if your handset is within the warranty period they will not charge any amount for re-installing the system software .And if your handset exceeds the warranty period they will charge some amount remember this is the only way to do it but doing it will erase all your phone contacts and saved messages i also had such now it is working fine
Thanking You
Kapil Das
Sep 21, 2010 | Haier Cell Phones
Linksys wrt54g use and instellation
All you need to do is go on internet explorer and type in 192.168.1.1 or 192.168.2.1 and this will get you to the setup page on the linksys, goto mac address filtering or wireless sevurity page, and allow your pc access to the router. On your pc you need to START - RUN - type "cmd" - type "ipconfig /all" - write down the physical address of your wireless card - type this into the set up page mac address filtering on the linksys.
Mar 21, 2010 | Computers & Internet
My ZTE cdma1X modem is not working on windows 7. please suggest
check this driver from here:http://www.giveawayoftheday.com/zte+cdma1x+card+driver/
Dec 01, 2009 | Microsoft Windows Vista Ultimate Edition
My mic is not working even after installing instel sound drivers what to do?
i m using the same mother board . if u r using the mic in internet chat rooms than u will have to download the latest drivers for your modem.or the mic is not working in widows application than u will have to download the latest sound card drivers.i use sound max drivers on D845PESV MOTHERBOARD it work FINE.U SHOULD ALSo TRY IT. THANKS
Apr 19, 2009 | Intel Desktop Board D845PESV For the...
D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
