Question about AT&T EP5962 Phone
My 2 year old base has power but no dial tone. It is not the power or the phone line. Is it done for? The handsets are searching for the base but I can not get any response from any buttons on the base to get the id # of the base to reregister the handsets. Frustrating because I have 4 handsets. I am wondering if I need to buy a new base for all of these headsets or if I can maybe get the base to respond or refurbish it somewhere. Does anybody out there have any advise for me? Thanks in advance.
This might sound silly, but have you tried plugging another phone into the wall jack to make sure it works?
Posted on Mar 10, 2009
My motorola Model K704B is saying "no line in what can I do to fix it
The "No Line" message means that the base of the cordless phone either doesn't have power, the line is damaged or that the handset/base are not communicating properly. To diagnose the problem, first check that the base AC cord is connected to a good outlet. You may want to unplug the cord from both the phone and the wall outlet and then plug it in again. (I've seen a case where someone turned off a surge protector and forgot to turn it back on; without power, the cordless phone won't work.)
To check if the problem is the phone line, I like to use an old corded telephone. Plug the backup phone in and check for a dial tone. If there is no dial tone, try a new RJ-11 cord. If there is still no dial tone, try the test phone at another jack. If you can, find the box where your telephone line service comes in. Open the box and look to see if there is an RJ-11 jack. If that jack is present, try using the test phone and listen for the dial tone. If there is no dial tone at the service box, contact your phone company. They should fix this problem for free. (It's possible that rodents have damaged the phone line outside of your home.) If the box doesn't have an RJ-11 jack, you'll need the phone company to test the service and repair it if needed.
If there is a dial tone at the service jack, then you have an inside problem. If there was no dial tone at only the first jack, you can check the jack itself. Unscrew the face plate and look at the back of the unit. There are two types of connections. If you have the screw terminals, look for a disconnected wire. Strip a new section of wire and secure it under the correct screw on the face plate. See http://cablesupply.com/content/47-telephone-connections-and-rj11 for the wiring pattern. If the jack uses a keystone, you'll need a punch-down tool that is available in many hardware stores in the electrical wiring section. Do not strip the conductor; just push it down into the correct slot of the keystone. If the problem is not at the jack, you'll need to check all of the wiring from the service box for damage. Your telephone company will do this for a fee.
If the test phone had a dial tone at all of the telephone jacks, then the problem is with the cordless handset and the base. One of the two units is not communicating correctly (transmit/receive). If your cordless phone is still under warranty, contact Motorola. If only one handset can be used with the base, replace the phone. If your cordless phone can pair multiple handsets with the base and only one handset is giving the "no line" message, replace the handset.
I hope this helps.
Feb 05, 2016 | Motorola Cell Phones
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
How do I reset my phone to reset to get back in range it says out of range anyone have instructions ?
Unfortunately, I do not have a manual for the GH-4102. However, most cordless phones get out of range messages at a few points: low handset battery, no power at the base or no dial tone at the base. Other possibilities are the phone base and handset lost the registration or one or the other isn't transmitting/receiving properly.
Things to try: unlpug the base power (from both the wall outlet and the phone) and phone line cord and remove the battery from each handset. Wait a few minutes and then reconnect the batteries and plug in the power and data connections. (Check when you unplug the base power adapter if it was warm; that indicates the unit was at least getting power at that point.) Recharge the handset batteries and then re-register the handsets, if needed.
Consider replacing the handset batteries if they are more than a year old (this includes the time that the phone may have been on a shelf after manufacturing). Try a new phone data cable (RJ11).
Next test your phone line and make sure that you have a dial tone. I like to use an old corded phone with the new phone cord for testing. If there is no dial tone, test the line at another jack. If there is still no dial tone, find your incoming phone line and open the service box. If you have a relatively new service, you will be able to plug your test phone into the service box and test there. If you can't test the line or there is no dial tone at the service box, contact your telephone company. They will test and fix outside problems for free.
If the problem is inside, look at all accessible wiring and make sure that the lines aren't damaged. If only one jack is bad, open the faceplate and fix any loose wires. There are two types of connections. The first holds the conductors under screws and the wire must be stripped back and secured. The other uses a keystone jack. The conductor wires are not stripped but a special tool punches the wires into place. You can find the punch-down tool at many hardware/home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring for the jack.
If your phone line has a dial tone and the above fixes didn't work, contact the company and get the phone repaired if it is under warranty (usually 1 year). If it is out of warranty, then decide if it is worth repairing or if you should replace the unit.
I hope this helps.
Jan 09, 2012 | Southwestern Bell GH-4102 Twin Cordless...
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
HELP?Why Does my telephone say connecting?
Most cordless phones will say connecting when the handset is out of range, the base has no power or the base does not have a dial tone.
I start my tests at the base and make sure that another phone (preferably an old corded phone) gets a dial tone at that jack. Try a new phone cord to check if the cable is bad. Check if the power brick for the base is warm and that the outlet has power. For some phones, you can reset them by unplugging the base and removing the battery from the handset. Then reconnect the battery and plug in the base. Check if the handset and base can communicate (try the Find Handset option). If needed re-register the handset.
If the test phone doesn't get a dial tone, then you need to find where you have a wiring problem. Try the test phone at another phone jack. If there is still no dial tone, find the telephone service box (where the phone line comes in). If you have a fairly new service, you will find an RJ-11 jack in the box. Plug in your test phone and check for a dial tone. If you have no dial tone, contact your phone company. They will come and fix the line for free. (If you can't use an RJ-11 cord at the service box, your phone company will test this outside connection.)
If there is a dial tone at the service box or at one jack and not another, it's an inside wiring problem. Look at any open wires (perhaps in the basement) for obvious damage. Open the jack and check for loose wires. (There are two types of jacks - one wraps the wire around a screw, the other requires a punch down tool to secure the conductors in the keystone. The conductors should be connected to the terminals in the correct order. To see a picture of the terminal connections that are used, see http://www.lanshack.com/wire_phone_jack.aspx . The punchdown tool is available at many home improvement stores in the wiring aisle.)
If your test phone had dial tone at the original jack and resetting the phone by disconnecting the power did not help, then the phone needs service. If it is under warranty, contact V-tech. Otherwise, you may be better off replacing the unit. These phones are not meant to be user serviced.
I hope this helps.
(if you add a comment with the model, then I will check if I can provide more details in my solution.)
Sep 28, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Cdp24201 base handset wont work
you just need to take the battery out and wait 30 seconds, replace it and it should be able to find the base. i had this problem and called olympia and this is the fix they gave me. It's worked for 4 years!
Sep 07, 2007 | Olympia CDP24200 Cordless Phone
AT&T EP5962 Phone Logo
204 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
