Question about Refrigerators
GE Profile not keeping items cold or frozen
We have a GE Profile (about 11 yrs old) and I just noticed items not staying frozen or cold in fridge side. The fan is running in the bottom. Inside both sides is producing air, just not cold enough. Before - this thing would freeze items fast and we had to keep the temps below the average (warmer) especially in the fridge side or things would freeze - up top
Could it be a simple - clean the coils in the bottom and around the fan? Is there a way to know if it is a bad compressor - sounds to listen for?
  • 150 Answers
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 21, 2009
HAVE A GE PROFILE SIDE-BY-SIDE REFRIGERATOR ABOUT 10 YEARS OLD THAT NEEDS A GARAGE REFRIGERATOR KIT INSTALLED. IN MY UNHEATED GARAGE AND NOT WORKING IN FREEZING TEMPERATURES. TRIED A 100w LIGHTBULB...
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Dec 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Have the GE GSH25JFT side by side fridge. It's
We had the same problem with our 2 year old GE GSH25JFT. Had a Sears technician come out and said it was the main circuit board. He also stated this would be $400 by the time the repair is completed. I just ordered the part myself from a Sears Service Center for $146 plus shipping. I believe the install is as simple as: unplug refrigerator, disconnect water supply, removing six screws, pull out the old circuit board and install the new one.
Oct 04, 2009 | GE GSH25JFT
Freezer is only cold not freezing, fridge is cool not cold
You will need to remove the rear panel in the back of the freezer compartment. If Frozen over defrost with a hair dryer. At the bottom you will see a defrost heater WR51X10101 Defrost Heater it has glass around the element inside and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Aug 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Jul 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig side by side 7-8 yrs old will not freeze frig not cold
Generally, This would be a sealed system problem. An inefficient compressor or low refrigerant. If you notice a build up of frost on the freezer panel it might be a defrost problem, but, I am leaning towards an inefficient compressor.
Jun 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
