Question about Acer Aspire 5610-4648 Notebook
Problem with video card
How i can update bios? because my video card do not work properly . In bios video card my detected as 8 mb :((( but must 128 or 256 ..
    President:
  • 2,653 Answers
Here it is:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Posted on Feb 21, 2009
My Graphic Card is malfunctioning
goto amd.com radeon drivers support tab on the right edge
choose the appropriate driver for your OSsystem
download and update
be sure your bios is up to date... microsoft may have fouled things up
this is a rather old video card
it is possibly a hardware error too
Jan 22, 2011 | Dell MRMGA8 RADEON X300 SE, (128 MB)...
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
Can u see the different of system board 374709-001 vs 374711-001
HP probably isnt lying to you. the video chip they replaced, 374709-001, was 128 Mb chip, your new one is 256 Mb. When HP installed the new one, the most likely failed to update / reinstall the bios. If the bios was not updated, the computer would not recognize the extra 128 Mb of graphics, as graphics chips are not plug and play.
If you provide me the model number of the computer i can link instructions on flashing the bios; However, i would call HP and see what they can do.
~gnomer
Feb 01, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Video card
well first of all you have to have the correct driver.
you should not have to delete or roll back but to be sure remove it from the device manager and then reboot let windows detect it when it starts back up and then point to the correct file to update when it asks.
Sep 03, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
No display at post
There are a few things that can cause no display on the monitor.
That single beep means POST = Power On Self Test. Post has tested everything on you're board to be good.
The cable between video card & monitor may be bad or not connected correctly (Swap out the cable as last resort).
2. You're monitor is defective, try swapping it with known working monitor.
3. You're video card is not functioning.
Lastly, when you reset the system cmos/bios everything went back to default. This means you're bios is now using the onboard PCI video graphics. Remove you're radeon 9600 video card. Try booting the system. You should see display again. The only way to test you're radeon would be to boot to the bios & set bios to boot using the AGP radeon. You need to change Init Display First to AGP & not PCI. If you loose video than you know you're AGP card is bad. Reset the cmos/bios before adding another AGP card or you will not get display. This setting is on pg 3-5. Integrated Peripherals. If you need you're manual you can download it from this link: http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Good Luck!
Mike
Jun 06, 2008 | Power Color RADEON 9600 (128 MB) Graphic...
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
Acer Aspire 5610-4648 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
