Question about EliteGroup P4VMM2 Motherboard
My problem is control panel conector
Pls show me what exactly to put the power led and power swicths...pls show me the manual of motherboard of elitegroup P4VMM2..thank you..
    President:
  • 2,653 Answers
Http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
If that's not it, check their US site. That should be it.
Posted on Feb 21, 2009
Conectores del panel frontal
Download a manual here:
http://www.motherboards.org/files/manuals/107/m5ssmv1110.pdf
You need a PDF reader to read content.
Good luck
Oct 17, 2012 | Soyo SY-5SSM Motherboard
Power sw, reset sw, and led conectors are disconected and i don't know how to conecte them
This diagram from the manual shows the front panel header location and pin functions.
Jul 30, 2011 | ASUS K8V-X Motherboard
I'm working on an Emachines T3624 I took out the front panel connectors and I can't remember where the power switch connects to the motherboard. I know the general area but I don't know the exact spot....
The manual can be downloaded here, just click on "drivers and downloads" and follow it out.
http://support.gateway.com/us/en/emac/default.aspx
I was hoping to refer you to the manual to provide a diagram, but the manual does not show the front panel I/O connections, so I'll give you general instructions.
The front panel header is a set of two rows of pins. You may need a magnifying glass and flashlight to see the small print on the motherboard that identifies the pins. Look at your front panel cables and look for the same abbreviations on the circuit board. You should see "pw sw" (power switch), "rst" (reset), HDD (hard drive activity indicator LED), and "pw" (indicator LED that shows that the computer is powered up. There should also be speaker.
Just match the cables to the pins on the motherboard. Polarity ( + or - ) is only important for the LED's ( pw and HDD ) Don't worry, if you connect them wrong, they just won't work, just swap wires.
Apr 29, 2011 | E-Machines T3624 PC Desktop
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
I had trouble with pins jumper on motherboard pc chips P23G.....and where is the pins conector for power,reset and led hdd & led power. thanx alot .
Here is a link to two versions of the motherboard you have. Figure which version you have and download the manual for it. Use the manual for your connector configuration and locations.
http://www.pcchips.com.tw/PCCWebSite/SearchResult.aspx?q=p23g&f=Products&MenuID=104&LanID=0
Oct 21, 2010 | PC Chips P23G Motherboard
I do not which pin is for the wire power, reset, HD led, - p ledand positive P led.
E 210882 Motherboard power swicth, rest swicth, HDD led, - P led and positive P led pins
Mar 21, 2010 | Dell (E210882) Motherboard
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
I don't remember where all the connections (Power led, sw led, etc.) attach to the motherboard of my HP media center pc 873n. Is there a diagram of the motherboard that shows exactly where everything...
I am not familiar with your exact motherboard, but most commonly, the front panel connectors themselves usually have white print labeling them, and on the motherboard, similar fine white markings will be next to the appropriate pins. This is not always the case, but the front panel pins on the motherboard are usually located near the bottom right hand corner.
Jun 09, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Where are the places of each jack??
Below is a link to the Manual for this Motherboard. Page 24 contains a diagram of where to plug in the front side led's and switches..
http://www.gigabyte.com.tw/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=15447
Pick any location except for the American server, it doesn't seem to want to download properly.
There you go, thank you for choosing Fixya!
Mar 20, 2009 | Gigabyte GA-6OX Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
EliteGroup P4VMM2 Motherboard Logo
127 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
