Question about Protron PD-800 DVD Player
I have Directv I don't know what step I am missing when I turn on the tv, then turn on the dvd put dvd in but somewhere there I am not doing something because when I hit play the directv is still on. The dvd is running but I have the picture from the Directv and not what is playing on the dvd. Can you tell me what step I am forgetting.
  • 8,596 Answers
The DVD player is plugged into one of the television's input channels, and the satellite is plugged into a different channel. You will have to take either your television's remote (not the staellite remote) or find a button on your television itself, and press a button that says "input," "source," "video," or "TV/VCR" and find the correct channel on your television that corresponds to the DVD player. If you give me the model # and manufacturer of your television, I can tell you exactly which button to press.
-Tha mp3 Doctor
Posted on Feb 21, 2009
Does the Sanyo multimedia prod-III connect to direct tv
What are the DIRECTV TV Apps and how do I access them ...
https://support.directv.com/.../what-are-the-directv-tv-apps-and-...
DirecTVDIRECTV's FREE HD TV Apps are interactive features that let you do all of the below without missing ... How do I connect my Genie® or HD DVR to the Internet?Missing: sanyo ‎multimedia
Media Share - DirecTV
www.directv.com/DTVAPP/content/directv/.../mediashare
DirecTVYou can quickly browse thumbnail images or create a slideshow. ... Set up Media Share by connecting your DIRECTV Plus® HD DVR to your computer.Missing: sanyo
[PDF]Programming a DIRECTV Remote to Work With Your TV
manuals.solidsignal.com/directvrc64forweb.pdf
Jan 20, 2016 | Sanyo Office Equipment & Supplies
Tip
DirecTV Remote Control Code Entry To enter a control code for your TV using...
To enter a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Locate the 5-digit code for your TV. (See DirecTV Remote Control Code List, page 14.)
  3. Slide the MODE switch to the TV position.
  4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
  6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 4 and 5, trying each code for your brand until you find the correct code.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
on Jun 10, 2010 | Televison & Video
Tip
  1. Turn on the TV.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
How do I get my Coby 15" hdtv to work with my
slide the switch on the top of the remote over to tv hold select and mute at the same time the green light on the top of the remote will blink green twice then press 9 then 9 then 1 the light on top will blink again then press the channel up button untill tv turns off then press select if you missed the code do the same steps but instead of channel up press channel down till the tv turns on it will only be a 1 or 2 pushes on the channel down if code was missed let me know if this helps
Oct 27, 2010 | Televison & Video
Need codes for proscan to put in direct tv remote
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
May 06, 2009 | Proscan 32LA30Q Television
Need to connect tv, satelite and dvd to yamaha rxv1700 receiver
hello i think the question is how to connect two equipment (dvd and directv) your tv has video 1 video2 aux, put one at any input and the sounds out from tv go to receiver inputs,this way you listen what is on tv in your amplifier....................saludos
Nov 24, 2008 | Yamaha RX-V659 Receiver
Hooking up Pioneer DV 250 DVD player through Directv Satelite Receiver
i dont know what hooks up were on my tv i have rca jacks but cant seem to get it all to play , hell i dont even know what channle to put the tv on, i do have a cable box to
Sep 17, 2008 | Pioneer DV-250
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Directv now on video 3, and VCR/DVD player won't work
Playing any source on Chan 3 requires RF coax cable connects hook-up.One is in from source box, other is out to tv.I think you have the coax cables reversed!.......T.
Oct 25, 2007 | Sony KV-36FS16 36" TV
Protron PD-800 DVD Player Logo
55 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
