Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The spin cycle for my
my whirlpool ultimate care II washer spin cycle does not remove the excess water from the clothes, The clothes is very wet after a regular wash cycle. There is noise during the spin cycle but it it is not spining _uacct = "UA-303641-1";urchinTracker(); _qacct="p-9dVjnoX8hqck6";quantserve();
  • 350 Answers
Dear shelldon39, Fri 2-20-2009 9:24pm EST (USA)
Some machines will shut down during the spin cycle as a precaution to prevent damage!
They will do this if you overload the washer with clothes and/or use too much detergent!
If this doesn't help please get back to me with more details!
jack
Posted on Feb 21, 2009
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II Washing Machine. Lately, the spin cycle does not remove all the water. How can I fix this? Thanks. Bill
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Whirlpool
Spin cycle pump is either obstructed or damaged. They are hard to get to and I suggest you call a local repairman.
Oct 22, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
357 people viewed this question
Dan Webster
Dan Webster
Sal De
