Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam stopped while I was recording and NO FREE DISC came on the screen
    Scholar:
  • 31 Answers
It sounds like your hardrive or other media storage on you multitracker is full. You must have done alot of recording. Go to your manual and read about how to transfer your work to your computer. It should be USB transfer. Or burn your files to disc if your unit has a burner. If you beileve this message is an error message of some kind and your multitracker is still under warranty, call tascam immediately. I had a problem with a unit like yours and it took a long time and calling them til they actually sent me a new one. Good Luck
Posted on Mar 17, 2009
What does it mean when says opc error on my tascam cd-rw 900sl?
So far as it looks from other information in the works that this problem is caused by defective media. I always use Taiyo Yuden discs and have had few rejections in over 600 discs. Supermediastore is where disc supplies can be had as well as information on the error rates of different media being produced. The complaints recently were due to a bad batch released of hhb brand discs.
Mar 17, 2013 | Tascam Cd-rw900sl Cd Recorder/player
Tascam md-350 "cannot copy" error
Like all home recorders, yours will not let you digitally record digital originals. The Serial Copy Management System (SCMS) is designed to prevent piracy.
Unfortunately it also means you cannot copy your own digital originals digitally.
Record them via the analog input. It will sound fine.
Nov 06, 2012 | Tascam MD-350 Advanced MiniDisc Recorder
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
When i record and try to play back i get nothing dpo2 . 2 tracks armed. i stop rewind and play and theres nothing , headphones can be heard when recording
Very likely the over-write head does no longer function properly. Try again with a MD that already has recordings on it, try to record another track to it. If the entire disc seem blank after TOC was written, the OW head is bad. At this point the unit effectively becomes a player only....
Mar 10, 2010 | Tascam Audio Players & Recorders
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
I cant record
You'll see this message if you try to create a song but there's not enough disk space on the partition to create a song. Free up some disk space and try again. The manual is at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 30, 2009 | Tascam DP01 All-In-One Recording Package...
TASCAM 2448 xp drivers
I have a tascam 2488mk11 whit no driver cd also .Tascam is pulling a scam
Jul 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam DP01 All-In-One Recording Package Microphone Logo
67 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
