When I moved my TV from the living room to the bedroom I tried turning on the TV but I instead saw the LED Light began to blink. I counted the blinks and the light blinked 9 times, what does that mean?
SOURCE: I have a sony Trinitron WEGA TV. Model
9 blinks is a zero crossing detector fault. This is caused by a malfunctioning detection circuit located on the G board. I have not seen many of the 32" models have this problem. But if you were going to get it repaired the repair should not be cost prohibitive somewhere in the 150 dollar range. It is usually a diode in this circuit that has changed it's specifications, the diode it's self will not test bad but the unique function it supplies to the circuit will malfunction because of this shift. Normally i see this on the 57" big screens and not the direct view, but both use the same power supply and use the same error diagnostics.
SOURCE: Sony wega model: kv-32FS120 doesn't turn on
Check your power supply board and resolder the pcb, check the switching diodes and zeners.
SOURCE: sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
