Question about Buffalo Technology (WYR-G54) Router
NAT Type Failed - PS3 - Buffalo Technology (WYR-G54) Router
  • smok3 May 11, 2009
    nat type fail my ps3 can connect to the internet web browser or store but i cant play online the internet settings say nat type fail whatever that means its hooked up to a hub and the hub is connected directly in the wall also i have a really weird ip address that starts with 132. so if n/e one can help plz let me know thanks in advance
  • 31 Answers
Contact your manufacterer of the router. they'll be able to explain to you what the nattype is and how to correct it. generally i'd suggest to ry connecting it directly to your modem but the nat type has nothing to do with your ps3 and has everything to do with your network setup. check all your security settings
Posted on May 20, 2009
quakefiend
  • 15 Answers
SOURCE: ps3 nat type 3
In order to achieve NAT 2, you are going to have to set your PS3 to a static IP address and forward ports on your router.
detailed instructions on how to do this and configure your ps3 can be found here:
http://www.pregamelobby.com/forum/sony-reviews-tips/5618-how-get-type-2-open-nat-your-ps3.html
In order to get into your router settings, go to 192.168.0.1 OR www.routerlogin.net (the router sets up its own DNS) and putting in your username and password. If you have not set up a password, the default username and password for this router is "admin"/"password". Follow the instructions in the page I posted once you are logged into the router's webmin.
Hope this helps!
Posted on Jul 21, 2008
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
  • 3 Answers
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Posted on Sep 24, 2009
anandg27
  • 1272 Answers
SOURCE: How do i change my router's nat type 3 to nat type
Instead of changing the NAT type, it is effective to forward ports on the router for your PS3. Perform the steps as mentioned in the below link:
http://www.portforward.com/english/routers/port_forwarding/Netgear/WPN824/PlayStation_Network.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Oct 09, 2009
  • 30 Answers
SOURCE: nat type changes back on ps3
you need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
Posted on Aug 10, 2010
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I can't change the nat type for ps3 or call of duty black ops how do i change the nat type
When you do a connection test on your PS3, what NAT type shows up; 1, 2, or 3. If you're worried about the STRICT NAT type in Black Ops, don't worry about it, the problem is the game and not your router.
http://forums.dlink.com/index.php?action=printpage;topic=21218.0
Feb 06, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I whant open in ps3
I take it that you want to change NAT type in your PS3. To open NAT type you first need to get port numbers from PS3 people. Once you get the ports check what the IP add on the PS3 is.Once you have this information login to the router interface and punch in the port numbers and the IP add and your NAT type should be open.
Hope this helped.
Jan 23, 2011 | LanTech (HR-114 II) Router
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
Jan 18, 2011 | Video Game Consoles & Games
My nat type on my Playstation 3 is nat type 3 (strict). I would like to know what setting configuration on my WRT54GX router so that the nat type decreases.
Well this becuse of NAT on the router
you can solve the problem by putting your PS3's IP address on DMZ in the router
access your router page (type 192.168.1.1 in the address bar of internet explorer)
username would be admin and password would also be admin
go to the DMZ and enter the IP address of the PS3 there after enabling it....restart your PS3....bingo your problem solved
Note:- you can check your PS3 IP address in the network settings and connections option on PS3
Hope it helps
Thanks
Jan 16, 2011 | Linksys Wireless-G WRT54GX Router...
I have a netgear WNDR3300 and my ps3 has a NAT type 3 how do i get it to a type 2?
You have to manually set the NAT type of your PS3 to type 2. I believe you can do that thru the interface. Most routers has NAT 2.
Feb 22, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Ps3 setting up static nat
are you in ireland and with eircom?
Feb 19, 2009 | Netopia 2247NWG-VGx Wireless Router...
Can't set my ps3 NAT type to type2
if your using a wired router,try putting in the username and password for your PPPOE.mine was nat 3 and went to nat 1 after i done this.check out youtube.let us know
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Buffalo Technology (WYR-G54) Router Logo
1,520 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
