Question about Dell Dimension 3000 PC Desktop
My Dell Dimension 3000 has no sound and says there is no sound device. What happened to it and how can I reconnect it?
  • 3,940 Answers
It is simple ! on the dell 3000 series.
First install operating system.
second install chip set drivers
Third install
And then the rest as you want.
If you do not do it in this sequence it will not work
tizz the manor the drivers go in that matters,
So again...Op system...chip drivers..sound...
Do you get it noW
Format again and do it right
Thanks Steve
Posted on Apr 25, 2012
2 Suggested Answers
SOURCE: sound windows xp dimension 3000
Replaced hardrive in a Dimension 3000, installed Windows XP Professional and have no sound. I go to control panel and the Sounds and Audio devices are grayed out saying No audio device installed. I tried to install the driver from Dell and I receive a message during setup that the Audio driver does not suport your computer hardware. There is only one driver and it is the R94481.exe. I did a diagnostics and the sound passed the test for the 8 tones. Other than that, I have no sound.
Posted on Oct 05, 2008
I have no active mixer devices any solution?
Try to Re-install your Audio Driver.Driver's cd is provided you with your motherboard.If you don't have the cd,then download your sound driver from following link -
Dell Dimension 3000
Aug 24, 2011 | Dell Dimension 3000 PC Desktop
My dell dimension 3000 makes cracking sounds when i play music
Check your speakers first. Plug the cable from your speakers into a cell phone, ipod or some other music device that has headphone port. If the speakers are crackling then, then you know it's the speakers. If not, then it's a computer issue in which case you might want to contact Dell.
Mar 30, 2011 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 showing the following LEDS on the back a-green, b-yellow, c-yellow, d-yellow, won't boot up.
if the Dell logo does not appear at all when you start the computer, unplug its power cord, press its power button for say 10 seconds to clear any power left to it. Next, try to disconnect all external devices connected to it, then remove the power and ide/sata cables to your hard drive and/or CD/DVD drives, remove all the memory and just reconnect 1 confimed working memory to the first memor slot. Remove any other cards like video card, or network cards, then remove and reconnect the power connection from the power supply to the motherboard. Reconnect the power cable and attempt to turn it on. If the back panel light code changes, try to re-connect the devices starting from the memory, then expansion cards and the storage devices one by one. After connecting each card or device, test the system to see which device may be at fault. If nothing changes, could be your power supply or mainboard and you may need to get the replacement for them. HOpe this lead you to the right direction in getting this solved. feel free to rate how helpful this information is. Thanks
Oct 14, 2010 | Dell Dimension 3000 PC Desktop
During a recent thunderstorm, the power fluctuated and my dell dimension 3000 turned off. There was popping sound and now I cannot power on the computer. When I take off the side panel, I can see a green...
The popping sound is most likely your power supply or something on your system-board like a capacitor.
If the problem is only the power supply:
If you want to see if you can salvage it try just replacing the power supply. The part is around forty dollars. You can google "Dell Dimension 3000 250w power supply" to find a deal on a power supply.Here is a link on how to replace the power supply in that computer.
Hope that helps.
Jun 03, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000 desktop and the sound from the cd/dvd rom drive is distorted or choppy when i play a dvd rom or a cd
hi go to start, settings, control panel, click on sound and audio devices. on the volume tab locate properties and click on it. now another box will appear look for cd volume and adujst it whist playing a cd until the sound is less distorted. please rate me if this solves you problem.
Feb 23, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000 and i can't get any audio sound. it came with a samsung sw-2525 CD/RW . come to think of it i don't get any sound through the external speakers. it has no internal...
check to see the sound is working under the control panel .. system icon click and goto device manager
you might have a bad driver for the sound device or the device is bad on the motherboard
also test under sound devices.. and set the default device to use ..
Sep 28, 2009 | Dell Dimension 3000 PC Desktop
I cannot hear sound a notice apear there is no device installed
I had that happen to me once on my Sony Vio and had to re-install the original driver. That fixed my problem. That was 5 years ago, and I haven't had any sound issues since. Hope this helps...:)
Jun 11, 2009 | Dell Dimension 3000 PC Desktop
Low sound
Go to Control panel and click on Sounds and Audio Devices, then click on Audio tab, then under Sound Playback click Volume. There you can adjust the sound for each device listed. If that does not solve the may just be your speakers.
Jan 13, 2009 | Dell Dimension 3000 PC Desktop
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 keyboard error
hai pls enable usb option in cmos and then press f10 and then press yes and then restart and see . or else reinstall the usb drivers
Sep 08, 2007 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
2,045 people viewed this question
Alun Cox
