Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I wented to add sata to xp
How can add sata to xp
  • Rob
    Rob May 11, 2010
    Do you mean SATA HDD support? Most SATA stuff is supported out of the box with XP. Can you be a little more specific as to what you wish to do and what you want your end result to be?
    Problem Solver:
  • 12 Answers
If *********** Board or power supply doesn't have sata connection you will need to buy an ide to sata adapter.
You can find those adapter here:
http://tinyurl.com/idetosataadapter
Posted on Mar 10, 2009
I cannot connect SATA HDD
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
The Bios sees my new SATA 750GB HDD but shows it as 0GB in Size and no options to format. XP does not see the drive. How do I format it from the BIOS Setup Menu? It is connected correctly.
so what is the 1st drive, and is it IDE or SATA.
or is one a
why are you using XP is it 32bit or 64? ill answer for 32..
its a dead OS,totally dead,and virus magnet and the MS PnP severs are shut down.
XP also MUST have the SP3 installed or the THING cant find any modern, SATA chips and many other devices.
im looking at your MOBO now,
it has 4 sata jacks
1 floppy
and 1 IDE jack let me guess this is what Drive one, IDE (pata)
is plugged in , then you add a new sata drive to the old sata ports
and XP pukesssss, as all XP does (cept mine)
SSDD. Same stuff different day,
so you can either use w7 like all savvy folks do
or find the driver missing that MS cant find, XP is dead.
but wait XP needs a Floppy drive to load the correct driver.
but if XP is running now, we dont need that only on XP installs.
ive no idea on what sata chip is there, in our shop
we scan it to find that and HP does not tell this.
Pentium D processor
Intel 945G Express
i think this is it , the 945G
load this driver from HP
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-dc7600-convertible-minitower-pc/472276
32bit
File name:
sp38488.exe (2.0 MB)
Nov 16, 2017 | HP Compaq dc7600 Convertible Minitower PC...
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
I have a gateway LT serires netbook, which i delete a partition on. i accidently deleted windows xp, and now it wont boot. how can i fix this with a flash drive/sd card
Yes it can be done, just follow this
http://www.vandomburg.net/installing-windows-xp-from-usb/
But since your hard disk is a SATA  and XP doesn't support it out of the box you will need to also add to the install stick the correct SATA driver. And since you are doing that you should add all the other drivers.
Mar 13, 2010 | Gateway Computers & Internet
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
How to disable sata on sony vaio vgn nr 110e
For information on how to install XP (without using a floppy which has the SATA driver) on a SATA drive go to this WEB site :-
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Sep 03, 2009 | Sony Vaio VGN-NR110E/S Notebook
Intalling window xp over vista
XP does not include SATA drivers in the distribution. You need to get the SATA drivers for your particular model from HP's website and watch for the prompt to hit F6 when prompted to install SATA or RAID drivers.
The trick is that the mechanism to add these drivers at this point assumes that you have a floppy drive which is rare these days. There are a number of work-arounds for this, here is one:
Aug 18, 2009 | Compaq Presario Notebook
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
