Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Fault code 37
Get a 37 fault code on 65 inch Mitsubishi dlp
  • 38 Answers
DMD fan error
Posted on Mar 13, 2009
Mitsubishi dlp wd y65 orange light blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 07, 2016 | Mitsubishi WD-Y657 65" DLP Projection TV...
Black smear across the screen
Sounds like DLP chip fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the sites by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 06, 2015 | Mitsubishi WD-60638 60-Inch 3D-Ready DLP...
Turns off a min or so after its turned on
Possible fault on power supply panel,seek pro help!
Dec 03, 2015 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
I am getting wide lines of bars on the screen after replacing dlp chip in wd- 73735 73" mitsubishi
you will need to pull the DLP chip out & clean the dust & foreign particles that got in while you had it apart.
Mar 11, 2015 | Mitsubishi WD-73735 73-Inch 1080p DLP HDTV
Diagnose tv faults
diagostic service line behind tv .
Sep 02, 2014 | Mitsubishi Wd-57731 57-inch 1080p Dlp Hdtv
4red and 8 yellow code flashing after lighting storm
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 18, 2014 | Mitsubishi WD-73738 73 inch DLP 1080p...
I have a Mitsubishi 65 inch dlp TV. It does not turn on. It starts to turn on but then suddenly it turns off very quickly. The red light is blinking. I replaced the lamp with a new one. still doe
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 04, 2014 | Mitsubishi Televison & Video
WD-82738 82-Inch six red blinks one yellow blink replaced chip to fix white pixels issue.
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Blinking code detail, and fault finding procedure to many brand TVs are given. Pull up older posts.
Nov 29, 2013 | Mitsubishi Wd82738-wd-82738 82" 3d Ready...
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
