Question about Acer PD726W Projector
Acer PD726 Menu doesn't work
I press the menu key both on the remote and on the unit with a source plugged in and the menu does not come up. Tryed unplugging unit, tryed using the software throught the computer. Still can't get menu to come up. Keystone doesn't work either. Source does work. Any suggestions
Try hooking up an active video source before you try the menu. I have the same projector, and it's a pain in the a$$ to work with. I've had problems with mine defaulting to wireless even with a d-sub connection present. If you disable the wireless to try to stop it, it goes black, and the menu won't come up. I usually hood a DVD composite source to the unit with a dvd playing, then I can get to the menu.
Posted on Mar 22, 2009
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
HOW TO RESET LAMP HOUR OF LG PROJECTOR MODEL BX-401C
The remote just says set 2 and does nothing
Does the TV screen say Set 2 or the display area on the DVD recorder? The original remote for the DMR-ES35VS doesn't have a screen. (If you are using a universal remote, I'm not sure how to reset the unit.)
The Set 2 indicates that the unit was set to listen to a remote on the second wavelength available on these remotes. Your remote needs to be set to the same wavelength. Press and hold Enter and then press and hold 2 (for about 2 seconds) on the remote to set it to this option. Press Return to move back through the menu or exit the screen. (Panasonic provided this feature for those with several devices so that each remote wouldn't control a nearby device at that frequency.) To get the recorder to respond to the remote, they must be set to the same range. To check, press the Functions button. Under Other Functions > Setup > Remote Control Code, you can adjust the wavelength that the receiver is looking for. (Use the up/down arrows to select a sub-menu and the Enter key to enter the sub-menu. Use the left/right arrows to select options in the secondary menu.) If the unit doesn't respond, try a different wavelength. (Press and hold Enter and then press 1 or 3. There are only three possible options for the remote/receiver.)
For a screen capture of this, see page 19 of the manual; it is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRES35V.pdf . An original remote is available from Remotes.com: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DMR-ES35VS&uuid=13262363222670 . It probably comes pre-programmed for Remote Code 1.
I hope this helps.
Jan 10, 2012 | Panasonic DMR-ES35VS
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
I have an acer aspire that i just got yesterday. i tryed to start it up last night and it started up. than i went to installed my internet stick on it the installion worked and than it went to a blue...
Hi.
Because the laptop is brand new there is nothing else we can tell that you haven't already done.
The only other thing that I can suggest is safe mode. If you can see the Acer logo or post information when you first turn the laptop on then repeatedly press the F8 key to get to the advanced boot options menu and then choose safe mode from the top of the list. Wait until the computer has booted and then click on the Start Menu > Control Panel > Uninstall a Program. Look in the list of installed programs for the internet dongle software and try to uninstall it.
If you can't see the program then I suggest that you use the recovery option to set it back to factory defaults.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
Choose option 1 and follow the instructions. If you have set up a password for Acer eRecovery then have it handy to enter it.
If after all this you are still getting the same symptoms then I suggest that you take advantage of the warranty and take/send the the laptop back as being defective.
Good luck!!
Jun 07, 2011 | Computers & Internet
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
Menu screen won't come up on screen
The "CONTROL KEY" may be set to "OFF".
In order to set the "CONTROL KEY" to "ON" without using the remote control unit, keep holding
down the ENTER button on the projector and press the MENU button for more than 2 seconds
Mar 27, 2009 | Panasonic PT-LB30U Multimedia Projector
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Tryed the code to unlock region
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
DVP 5106k
1 - Make sure there is no disk in the player
2 - Press EJECT on the remote or on the player. The eject icon has to be visible on screen for the hack to work!!!
3 - Press MENU (System) on the remote
4 - Press the RIGHT button on the remote until you get to the PREFERENCES screen
5 - Now enter the sequence 135566 with the remote control
6 - Now "Region Code" should appear
7 - Select the 0 (multiregion)
8 - Press MENU (System) on the remote to exit the setup screen
9 - Press the power button on the remote to set the player on standby, this saves the new setting.
Apr 19, 2008 | Philips DVP5140 DVD Player
Acer PD726W Projector Logo
352 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
polytek
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
