Question about Whirlpool Washing Machines
Question about my washer
I have a front loader,whirlpool,i put the clothes in,and started,it begins to fill up with water,then it shows f-11 ,and won;t go any where
  • 150 Answers
Sounds like your loosing the cycle timer or your control board.You may have to replace it,try doing it yourself.
Len
Posted on Feb 21, 2009
I have a whirlpool Duet Front loader Washer Model GHW9150PW4
there is a book inside the washer in bottom or back that gives you the trouble codes
Jun 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds indication
Hi!
For a top loader, a general rule of thumb is to lay clothes loosely inside the washer until they reach the top of the agitator. For a front loader, fill it until it's full, with minimal compression of the clothes.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
Apr 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Can I make the water level on my whirlpool duet washer higher?
its because of the design of the machine they are water efficient.a front load uses any where from 15 to 18 gals. compared to 40 to 50 gals.for a top load. they also have a higher spin rate than the top loader,therefore making your close dryer and having a less drying time in the dryer.energy efficient too!!
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
My washer doesn't get enough water in it to wash properally.There isn't a water level knob on the washer.Its a frontloading whirlpool.
There is most likely nothing wrong with the washer. Front load washers will only fill about 2 inches of water in the tub. As the load starts to tumble, water is absorbed into the clothes, causing the water level to drop. The machine senses this and adds more water. The process continues until the water level stabilizes. (thus no need for a water level switch) Your clothes should get wet, but you will little if any water. If you use a gentle cycle you will get slightly more water, as the washers tumble at the same speed for all cycles, but give a more gentile wash if there is more water in the drum.
Also,..... remember because you have so little water in a front load washer (compared to most all top loader models) you want to use only 1 to 2 (max) tablespoons of HE detergent per load!
Aug 27, 2008 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
