Question about HP Compaq WF1907 Monitor
Static on Screen
White static horizontally on screen won't go away with any adjustments.
  • Anonymous Mar 12, 2009
    Exactly the same problem.
  • 298 Answers
Is this an LCD type of monitor or CRT? either case, there's a problem with the horizontal IC. My best solution for this case is to have the unit serviced by an authorized personnel as meddling with the internal circuits of the monitor is dangerous.. Have them estimate the price for repair, if it costs too much... better buy a new one.
For CRT type of monitors: try degaussing, this feature can be found on the OSD (On Screen Display). This can be accessed by pressing Menu on the monitor buttons.
Hope this helps!
Posted on Mar 16, 2009
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
Sony KP-57WV700
Hi. It seems that the g2 voltage of the picture tube is too high, resulting in a white screen, often with white horizontal lines. The g2 (= second grid) voltage is derived from the flyback high voltage. The voltage divider is mostly integrated in the flyback trafo housing.(including the adjustment knobs). A failure in this divider may lead to this defect. The static you hear may come from sparking in the divider. The flyback trafo is soldered onto the main printed cirrcuit board. Sometimes, one of the pins sits loose in the soldering pads.
Turn on the set and observe for any sparking around the entire flyback circuitry, and, or the flyback trafo itself
The screen turns black after a while, as a too high beamcurrent is detected. The set disables the flyback. Stand-by blinks meaning that there is a fault condition.
Be carefull with the high voltages. The flyback voltage is very high (20-30 Kilovolts !) and may be lethal !!
Jul 02, 2012 | Sony KP-57WV600 57" Rear Projection...
I have a LG 42lh30 it's only about 1 1/2 years old and recently 1/8th of the screen in lighter than the other with really little lines through it, like unmoving static. If we plug the CP in via HDMI it...
Hello. Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). It looks like your next step is to replace your TV.
Oct 05, 2017 | Televison & Video
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
Screaming static
Try turning off different lights near the room or in the room that it is in. Our tv does that if the overhead light in our bedroom is on, it's a room right next to our living room.
Jan 14, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Blurry Image
Congrats on changing the fly and getting it to come on. If it is a sony as it looks at the top of this page (accurate model?) need only to adjust focus and/or the horizontal static control. can't tell you where the horizontal static control is exactly but there are large wire associated. If not a sony then adjust the focus on the flyback.....top control bottom control is screen or for brighter picture.
Mar 16, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Hitachi 42edt41green static
i had this problem to,
what i did to fix mine, take the back off and find the ysus board there are pots on the y sus board that you can adjust with a screw driver mine has 4 on it i adjusted the the two more accessible ones and the problem is gone
Nov 27, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
HP Compaq WF1907 Monitor Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
