Question about Palm Treo 755p Smartphone
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers jawbone 2 that he purchased retail, and his blackberry storm will recognize his jawbone, but not mine. I tried pairing with his and my treo won't pair up with his jawbone2 neither. Please let me know if there's a problem between the treo and jawbone2 or is the obvious evident. I bought a dud.
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Posted on Feb 26, 2009
This problem is really easy to solve. The Jawbone 2 has two places to press in order to pair: the Noise Assassin button AND the Talk button. Hold down those two buttons. You'll know that it's pairing when it blinks white and red alternating. If it blink white once, and then only blinks red, that means it's not pairing, the headset is just turned on. Turn off the headset (hold down talk button for three seconds) and try it again. Be patient. Also, go to add a device in trusted devices first.
Usb charging port fell off inside my Aliph Jawbone Jambox Blue Wave Wireless , opened it up and have to find battary cause circit board broke off with port! wtf the usb port is always coming off stuff
A Jambox is a wireless speaker, not a phone. Anyone claiming to know the answer while referring to phones clearly doesn't know what they're talking about.
The question is mis-filed under cellphones, but the respondents so far don't seem to care that it's not a phone at all. :D
Take a look here: https://www.youtube.com/watch?v=X5APtwqtEps
Apparently this is a very common problem with the Jambox, so contact support first and ask them to replace it.
Mar 03, 2013 | Cell Phones
How to pair an aliph jawbone to my phone
turn the bluetooth option on from your evo and make sure that the bluetooth is discoverable and that press & hold down the power button on the jawbone bluetooth till you see lights blinking red & blue or its blinking red only on some jawbones , that check your phone , it should show u a jawbone bluetooth discovered on device than hit connect or pair , enter 4 zeros (0000) to connect & you should be able to use it like a champ , good luck , thank me if i help out on you Question
Feb 02, 2012 | HTC EVO 4G Sprint - /
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
I can't get my jawbone to pair with my palm centro any idea's
With the jawbone turned off, press at the same time the turn on button and the noise reduction button. The jawbone should blink white and red for three minutes, in that time you shoul be able to find it as a bluetooth device in the free hnd configuration of the palm centro. than yu complete the conection by inserting the code. The next time you turn on the jawbone it will connect with te palm.
Aug 09, 2009 | Palm Treo 500 Centro
I have a jawbone bluetoothe and i want to program it to my cell phone
The instruction that come with the Jawbone don't give exact instructions for making it go into pairing mode AFTER it's done it the first time... here is the way to do it on a new phone:
Summary
New Jawbone pairing troubleshooting
You can view this answer at
http://aliph.custhelp.com/cgi-bin/aliph.cfg/php/enduser/std_adp.php?p_faqid=96
Jul 31, 2009 | Cell Phones
Pioneer BT Unit 2- In Car Bluetooth not working!!
Sounds like it finds the stereo, but won't pair? You need to check with Treo. I know that my Treo 700WX did not pair with my stereo headsets until I downloaded a patch upgrade to the phone.
Jan 28, 2009 | Pioneer AVIC-D3 Car DVD Player
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Loading Palm Treo 755p Software onto laptop with Windows Vista
Make sure it is a 32bit operating system on you laptop...if your operating system on your laptop is a 64bit it will not work. Check the Palm support website to see if they have a current download
Jan 06, 2009 | Palm Treo 755p Smartphone
Jawbone bluetooth does not charge
My jawbone was not charging at all, but then I looked at the prongs on the charger and I saw that one of them was shorter than the others, so I got a pair of small needle nose pliers and gently pulled on it. It returned to its normal length and I plugged it up. It is now charging normally.
Jawbone should design a better charging system.
Dec 14, 2008 | Cell Phones
Bluetooth pairing with Lexus
Try using the following code: 0000 on the Palm Treo and your car's device. It worked for my BMW 328i
Nov 11, 2007 | Palm Treo 700p Smartphone
Palm Treo 755p Smartphone Logo
432 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
