Question about Dell Inspiron 530 Desktop Computer
Ineed to reset network adapter each time I turn on wired desktop
I have tried two linksys routers and with each one on my vista computer I need to reset network adapter each time to get the internet. My wireless works fine, only the wired computer from the router has this problem.
  • 2,653 Answers
You should check to see if there is a router firmware update and also one for your network adapter. You can use Dell's support website for the adapter
Posted on Feb 21, 2009
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
We have a new laptop, and desktop and a linksys
by default all laptop has wilreless adapter inbuilt in it
but desktop doesnot have wireless adapter
if you have wireless adapter on all laptop and desktop
in that case
reconfigure wireless setting of router
changed ssid and network key
Mar 14, 2010 | Linksys Computers & Internet
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to and download a win 7 driver there. They show a 48% success rate.
Dec 13, 2009 | Belkin Computers & Internet
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Vista internet connection through Linksys router only partial
Go to Network and sharing center, then network connections, right click you your network connection and choose properties. Then choose Internet Protocol Version 6 (TCP/IPv6) Does it say "obtain ip address automatically" ? Do the same for Internet Protocol Version 4 (TCP/IPv4).
Dec 25, 2008 | Computers & Internet
I can't reach my ip to change my lan config
The default IP Address for Linksys routers is You may want to try accessing your router's configuration by typing this IP Address in your browser.
If you have any additional troubles, please let me know.
Jun 02, 2008 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Linksys WRT54G wireless router problem using Vista
The following is not a solution but a set of steps to determine an issue. Wire the router back up -- connect a computer to it using a wire -- can it access the internet? If so the WAN side router config is fine. The issue appears to be a wireless issue. Did the wireless card lose the proper configuration settings to access the router? Did the wireless adapter disconnect and need to be reconnected?
If nothing above was an issue we need to do some other testing -- I do not believe this is likely in this scenario where things were working -- but as we have not yet found out a cause.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and one wireless computer attaching to the linksys router I want you to do the following
Click Start then All Programs1.gif then Accessories then Command Prompt
In the window that opens type
ipconfig /all
The back in the window enter the following command using the default gateway from the wired connection (your router address)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
Wired IP address 192.168.1.u
SubNet Mask ?.?.?.? assuming
Default Gateway
DNS addresses ?.?.?.? not
where at least one is not zero.
Then wireless entries should be
Wired IP address 192.168.1.u should be 192.168.1.u
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
Dec 16, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Dell Inspiron 530 Desktop Computer   Logo
122 people viewed this question
Alun Cox
