Question about Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
  • 1 more comment
  • lippz69 Feb 21, 2009
    pleease,i need an answer.
  • jamie Feb 22, 2009
    will a sony xm-1652z 1000 watt amp run 2 dvc 4 ohm 800 watt subs and if so,what is the best wiring option that i have?thank you.i need a response bad please.
  • Stephanie Willis
    Stephanie Willis Apr 19, 2013
    two of the subs are 300 watt & the third sub should also be 300 but if not at the very least would be 200 watts
    Problem Solver:
  • 11 Answers
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Posted on Feb 24, 2009
  • Cory Tubbs
    Cory Tubbs Jul 20, 2011
    i got a sony 1652z 1000watt amp. whats the best way to hook up two dvc 12" audiobahn special edition subs?? email me ghetto_red2005@yahoo.com thanx 4 the help
What speaker componets do need to buy?
  • 1000W max power
  • 165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
  • 200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
  • 400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
  • OTL (Output Transformerless) circuit
  • Pulse power supply
  • Line & High Level Inputs
  • .3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
  • 80 Hz, -18dB/octave Low Pass Filter Switch
And i would say that the best use of this amplifier would be for sub-woofers.
Feb 19, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub wiring
IF THE RMS IS 800 THEN THAT IS THE MINIMUM YOU SHOULD RUN TO THEM. IF THE MAX IS OVER 1000 WATT, YOU SHOULD BRIDGE ONE SPEAKER TO EACH CHANNEL. YOU WILL PUSH THE MOST POWER TO THEM THAT WAY. MORE POWER = MORE BASS
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Will a sony 1000 watt amp model # xm-1652z run 2 dvc 800 watt rms subs?if so,whats the best way to wire them to this amp?thx
personally i wouldnt use a sony amp for powering anything but,however if your going run it what i would recommend is if the speakers are at 4 ohms then run in series per speaker then put the speakers in series as well so you will keep your 4 ohms then run the amp in mono,however just to let you know that amp will not push fubars enough to really make them thump my advice is to goto http://www.sonicelectronix.com  if you have 200 dollars you can get a nice  Hifonics TXi 1508D that will push those monsters quite well thats 1 ohm stable and will barley get warm even after hours of thumpage,also if your running subs monoblocks are the way to go hope this helps you out.
Feb 21, 2009 | Power Acoustik Power-Acoustik FUBAR-12W...
What is the rms
Root Mean Square
You can read about it here as well as the formulas you need
http://en.wikipedia.org/wiki/Root_mean_square
Robert
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony amp model 1652z
1000W max power
<b>
</b>
Pulse power supply
Amplifier and subwoofer
Yes, it should have little trouble. You will be best to keep it 2-channel and get another Sub. then run both. if you bridge it you will blow your 1 Sub. DON'T FORGET to put a in-line Low Pass Crossover in front of the Amp. OR any Sub.(one for each if you do go for 2) as they were never made for the high frequencies. An adjustable one is best for fine tuning. In thory you have a 600 watts buffer that way. If you do it Mono you are 400 watts over. If you want to go Mono you will need over 2000 watts on the Sub. end to turn it right up. Oh and some good ear-plugs if you want it loud whilst you are inside the car.
Dec 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
295 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
