Question about Power Acoustik PTID-4003TV Car Video Player
I need the e brake bypass code for the power acoustik ptid=4003
I need the e brake bypass code for the power acoustik ptid-4003
  • hornrodrick Apr 21, 2009
    i need to know hoe to bypass my parking brake on a power acoustik ptid-800in
4 Suggested Answers
hogan doan
  • 227 Answers
SOURCE: Power Acoustik PTID-4005 BYPASS BRAKE
Just ground you brake wire directly to the metal frame. It should work fine. Goodluck.
Posted on Mar 07, 2008
MrVanDango
  • 7 Answers
SOURCE: region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Posted on Aug 08, 2008
SOURCE: how to bypass e-brake to veiw movies all the time
HOOK IT TO THE GROUND WIRE (BLACK)
Posted on Nov 20, 2009
  • 547 Answers
SOURCE: bypass having to use the parking brake on power acoustik ptid7250
no, you can't, because watching a video while you drive is an insanely stupid thing to do.
Posted on Feb 04, 2010
How can i get a harnest and plug for power acoustik PTID-4003 car video player
Call Power Acoustik and tell them you had it for a few years and used it in a few cars so the harness has been chopped so short you need to get a new one. I'm sure if it was originally yours, they will want a receipt for the stereo brand new and they may sell it to you if it is available. If not, I sell new Soundstream Stereos at a very low discounted rate, as well, Power Acoustik.
Check out the link below, we are the lowest price online for any of their products because we are closing all of the products out since they have driven the product line down to portray them as low as Dual and Craig., as a matter of fact, the products are all great, but, they do not protect their dealers and allow distributors to sell them online on Ebay, cheaper than the delaer's cost with free shipping, which has driven us away from them because we can't make a profit.
Anyway, they should be able to sell you one, if not, give me a call or check our site, we sell their distributed products as well and may have a harness available on the website.
Marc http://advancedelectronic.net/
Nov 25, 2014 | Power Acoustik Car Audio & Video
Tip
Bypass
just ground the wire to some metal that is on the brake
on Sep 01, 2008 | Power Acoustik PTID-4003TV Car Video...
Need a code to by pass parking brake feature
usually not a code. it is unlawful to drive without the parking brake feature hooked up.... but the way to do it is remove the wire from the parking brake and ground it. it will then think the parking brake is on
Feb 09, 2011 | Power Acoustik PTID-8300NR Car Video...
Bypass having to use the parking brake on power acoustik ptid7250
Feb 03, 2010 | Power Acoustik PTID-7250N Car DVD Player
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
Region free code for power acoustik ptid-5300
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Mar 03, 2008 | Power Acoustik PTID-4005 Car Video Player
Power Acoustik PTID4003 AM/FM/MP3/DVD w/3.6 TFT PTID-4003
he has to buy a mounting kit and wiring harnest for your car so it will fit in right. when he buys that there will be instructions that come with it. i hope this helps
Jan 14, 2008 | Power Acoustik PTID-4003TV Car Video...
PTID-5800
Yes you can...i have seen this done.
Get a switch from walmart with 3 plugs to it, 1 for power, 1 for acc, and 1 for ground. Splice the ground and battery cords and attatch them accordingly to the switch. The back cable...i think its pink or orange attach to the accessories....should be the one in the middle on the switch... WHen the switch is off then you can watch while you drive...hope i helped
Jan 05, 2008 | Power Acoustik PTID-4003TV Car Video...
Power Acoustik PTID-4003TV Car Video Player Logo
619 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
