Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
The little toothed belt on my bissell shampooer broke got a replacement but don't know how to put it back on Stark's where I bought the belt wouldn't help me man said he isn't a mechanic. well neither am I so could you send me a diagram I could follow? Thanks
  • docpower8411 May 22, 2009
    smooth belt smokes and toothed belt broke, how do I replace them?
    President:
  • 389 Answers
Hi!  Your question has come up under Bissell ProHeat, although you don't actually specify that model. Assuming it is, the belt change operation is quite simple but hard to describe in words (it will sound much more complicated than it actually is, and is further complicated by the fact that there are two different belts, one on each side of the machine!)
Your best bet is to go to the Bissell website (www,bissell.com), find your exact model, and then you can download the user manual which shows you, with illustrations, exactly how to do it.
Good luck!  I value your feedback. If this has helped, please remember to rate me.
Posted on Feb 21, 2009
    Problem Solver:
  • 8 Answers
Posted on Jul 27, 2009
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
How to change the belt on my bissell 12amps powerheat shampooer,
the belt is simple there is a door on the side of the machine remove it and you will have easy access to the belt. For the other problem use this repair guide.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Troubleshooting_ProHeat2X_9400F.pdf
Apr 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
Need directions for changine belt for brushes
There is a door on the side pop it off remove the old belt and simply slide the new belt on. Over the motor shaft first then the roller brush end.
Apr 12, 2009 | Vacuums
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat Shampooer
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
Jul 03, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell shampooer
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together. This is for alot of models, but you didn't state your model number, hopefully this is the right fix for yours.
Nov 14, 2007 | Vacuums
I don't know how to advise you on this. The Bissell is pretty complicated when you take the hood off. Under there is a number of things that must be in place correctly to replace the hood. There is a small plastic "rod" with an "o" ring on it that controls the shampoo mixture and that has to be positioned right to replace the hood. You may have to take the machine to an experienced shop to have it re-assembled. I don't think I can tell you all the little things you have to do to re-assemble it yourself.
In regards to the elevator, there are two arms that lift the brush off the floor when the handle is put in the upright position. This is so the brush will rotate freely while you use the hose. These arms break quite easily and are available from any repair depot in a set.
You may be able to get a schematic diagram from a warranty service dealer. They have a special "dealer only" web site that they can access to get repair and parts info. Usually, they can e-mail or fax you information if you're really nice to them. Smile when you're on the phone. :)
Nov 08, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
368 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
