Question about HP Officejet Pro K5400dtn Printer
On button flashing and paper feed button flashing - new purchase?
Have put new printer together K5400 dtn/ paper in both trays/loaded discs but can;t tell if they were successful in loading??
Inks full.
  • Anonymous Mar 18, 2009
    i have a problem in officejet pro k5400 of paper pickup and flasing both poweron botton and paper pickup button.
  • HP Master
  • 419 Answers
Please see your duplicate problem posting for the solution:
http://www.fixya.com/support/t1691524-k5400dtn_paper_feed_buttons_flashing
Posted on Feb 21, 2009
I have a Brother model HL-2040. The printer was working fine. I put some additional paper in it and clicked print and all the lights started flashing. I looked for a paper in the printer wrong and...
Red paper light is on means that there is no paper fed in the machine. Follow the steps below to clear this issue:
- First remove the paper tray from the machine. - Then remove all the paper from the tray. - Fan the paper well or run your fingers through the edges of the paper. - Adjust the paper guides of the tray. - Then reload the paper back to the paper tray. - Put the paper tray back to the machine. - Lastly press the go/blue button.
Printer should print the document.
Hope this helps. Rate if it works. Thanks
May 09, 2011 | Brother Office Equipment & Supplies
I am getting flashing error messages 'Supply REC. Paper Tray: LTR' and 'Received in Memory'. There is no paper jam and there is paper loaded in the tray. I have also tried to manually feed paper. I have...
Hi there:
I had the same problem and it made me crazy. All you have to do is pull out the paper tray, pinch the very back wall of it (I think it has a blue button to pinch) and slide the very back of it forward so the paper is snug in the tray. Put the tray back in and it should go away. :)
Hope I helped........
Mar 09, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP 1022 Laserjet Feed Problem?
Try to cold reset you printer
Power off the printer.
* Power on the printer while pressing both the Go and Cancel buttons.
* Keep the buttons pressed. The lights will begin to flash in sequence.
* Release the buttons when all three lights begin to flash in union.
Printer is now reset
Try to send a test print now
Keep me posted!
Cheers!
Nov 13, 2008 | Office Equipment & Supplies
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
Paper feed
Fixing paper feed problems
  • Ifthe printer is not picking up paper, check to see if there is paper inthe IN tray. If there is not, load paper into the IN tray and press thec00153917.jpg RESUME button.
  • Do not load more than 100 sheets of 20-pound paper in the IN tray. The paper stack should not exceed 10 mm or .38 inches.
  • Use the same type paper in the paper tray when you are printing.
  • Makesure that the paper width adjuster is against the left side of thestack but is not blocking the stack. Push in the paper length adjusterto make sure that the paper is fully seated in the printer. Do not pushso hard that the paper buckles.
  • Do not use paper, envelopes, or cards that are torn, buckled, have curled edges, or do not lie flat.
  • Ifusing the IN tray to load several envelopes, push the paper lengthadjuster toward the envelopes until it stops. Do not bend the envelopes.
  • Load only one envelope at a time in the single-sheet input tray and be sure that it is inserted fully into the slot.
  • Use envelopes with square flaps instead of triangular flaps, or tuck the flaps inside the envelopes.
  • Ifthe printer's paper feed rollers become covered with debris (dust orpaper fibers), clean the rollers with a soft cloth dampened with water.
  • Ifthe paper loads unevenly in the printer, one or more of the rollers onthe rear access door is missing. Remove the rear access door and checkto see if all six rollers in the door are present. If any are missing,the door assembly needs to be replaced. This is a customer replaceablepart, number C4557-60076.
  • Ifthe printer does not drop any paper from the wings to the OUT tray,remove the excess paper. The paper stack should not exceed 10 mm or .38inches.
  • Ifthe printer is sending more than a single sheet through at one time,remove the paper from the IN tray and separate any sheets that arestuck together. Reload the paper in the IN tray.
  • Ifthe printer is not ejecting paper, then turn off the printer. If yourcomputer is turned on, turn it off. Then, turn on the computer. Wait afew seconds. Turn on the printer.
    NOTE: If you continue to experience paper feed problems, try other media or paper types. Refer to the User's Manual for supported media types and specifications.
Jul 09, 2008 | HP DeskJet 710c InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP Officejet Pro K5400dtn Printer Logo
101 people viewed this question
Ben Johnson
