Question about RCA F27650 27" TV
Channels above 70
I cannot set the channel to 73 which I need to run my bell express vu second TV
  • 75 Answers
Go into menu and change tv setup from attenna to cable
Posted on Feb 21, 2009
How do I get the tv on channel 73?
Instead of doing an automatic scan of TV Channels, you might have to go into the setting and manually add channel 73.
If it's not an actual tuned channel, chances are that's why an auto-scan wouldn't find it.
Feb 08, 2015 | Televison & Video
Sony TV is locked, how to unlock with the remote control
I just got off a friend an old Sony TV. I was able to hook up my bell express vu to the television, however every 3 seconds once I am on a channel, the screen goes black and a little yellow lock is in the centre of the screen. How do I stop it from doing that ?
Apr 15, 2011 | Konka K2386U 23" TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Need codes for bell express vu satellite for innovage products jumbo remote
Press and hold tv until red light flash , press code search , press channel up until the tv goes off , then press record and your done
Feb 10, 2009 | Big Button TV Universal Remote
CANNOT ACCESS CHANNEL 76
Just go into ur option , u can change for what channel ur second tv need to bon on , so u can put a channels ur tv can get . I dont remberber where it is in the menu , but im sur u will find it in a few minutes , if u select air or cable whatever it is for the channels , make sure ur tv is on the same ... Hope it will work fast and it will :)
Jan 03, 2009 | RCA F27650 27" TV
Need codes for jumbo universal remote for phillips tv and bell express vu
Press the tv and hold it until the red light flash , then press code search , press channel up until your tv goes off , press record and that it your done . Will work for your tv but maybe not for the express vu receiver , this way of finding code makes the remote trying them all so if it dont work on your express vu remote , no other codes will .
Dec 08, 2008 | 2006 Honda ANF125 Innova
Channel search for my Phillips PL9125
You should contact to get original remote for that TV.
Nov 05, 2008 | Philips Televison & Video
Switching from TV to CATV
it sounds like the tv is already in cable mode, and that it is a older tv. some older tv's will only tune in so many channels. yours going up only to channel 69. if you have the remote for this tv, try punching in channel 73. if it doesn't tune in, then the tv will not recieve channel 73.
good luck
wg
Feb 05, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Not enough channels
The history of broadcasting is one of adding more and more channels. The older the VCR, the less cable channels it will get.
Jan 01, 2008 | Toshiba W522 VHS VCR
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
