Question about HP Pavilion ze4300 Notebook
When my laptop starts up I receive a message which says "media test failure chech cable" what is the solution for this
  • donaces Mar 18, 2009
    lap says media failure check cable i have a hp pavilion 6300
  • lars51500 Apr 21, 2009
    laptop keeps going on and off continously
    President:
  • 2,653 Answers
Usually means hard drive crashed.
Posted on Feb 21, 2009
PXE-E61 media failure check cable
PXE-E61 Error message showing due to Media cable failure.
You have to fix this media cable failure one must return to the BIOS screen at start up. Depending on the model of the laptop, press f1, f2, or delete to enter the BIOS screen (the computer will tell you what keys to press). At the bottom of the BIOS screen, there will be a menu. One of the options should be "setup defaults." By pressing the corresponding key, it will return all of your settings back to how they where originally.
Hopefully it will help you
Jun 26, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
PXE-E61 Media test failure
See this on-line thread from other users. I'd be leary about the posts that advocated hitting the laptop...
http://www.nocrash.com/ncbbs/msgs/3247.shtml
Portable computers can suffer from bad connections easily, so the first thing you should check are that all cables and other connections are tight and seated firmly.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
Media test faiture, check cable error message ,
The error is related to your network interface card. In a lot of laptops this is integrated to the motherboard and can't be switched out at home. You will need to take the laptop in for service to have the card replaced.
Sep 27, 2009 | Sony VAIO Notebook
When i turn on my compaq presario 2100 the screen keeps on going to -media test failure- check cable. then it says to press any key to reboot system.
your hard disk might have gone bad or its just a losse connection if its a loose connection just chech it or else replace it with new one
Aug 03, 2009 | Computers & Internet
Problem:ther's a media test failure. check the cable, what's recommend move
Check the cable.
Seriously, how about some more information? What kind of Mac? What media? What were you doing when you got this message? What device were you trying to use? An external DVD drive? A printer? A RAID array? A DVR?
Apr 19, 2009 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
HP Pavilion ze4300 Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
