Question about Maytag Atlantis MDE7400AY Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
One of the three paddles inside the dryer is coming loose. I want to fix this myself, but need to know how to get to those screws, please.
  • bikeman2224 Apr 03, 2009
    I have the same issue, does or did removing the back panel solve the problem?
  • 150 Answers
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Posted on Feb 21, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Two of the three fins had broken off in my MCD7600. to replace:
1) remove the door from the front (2 screws) and the hinges will pull straight out
2) remove the 2 white blocks/covers on the opposite side
3) the front panel will then pop out and lift up and off
4) there is a small (2") bracket that is holding the top on, remove those and the top will flip right up as it has hinges on the back for this purpose
5) now you can easily (from the bottom) find the screws and replace (from the top) the fins that have come off
good luck
Posted on Apr 24, 2009
The blade inside my Maytag Atlantis dryer is loose. How do I fix it?
if it has the sloped front and door at the top front,then open door and remove 4 screws 2 on each side remove door then there are 2 screws under front of top cover remove these, then pull outward on door from edged of front cover to remove, then lift up top cover,then you can tighten or remove and replace paddles
Mar 11, 2012 | Maytag Dryers
I have an MDE7600AYW electric dryer and two of the three fins came loose inside the dryer and one of them is now lost. Who can I contact to purchase a new one with the installation screws???
The fins are called "Baffles" and you can find the parts at the link below:
http://www.partselect.com/PartDetail.aspx?Inventory=2035811&SourceCode=1
Jan 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
My dryer squeeks when running
Hi, I've had a similar problem (I think) on my MDG7400 dryer. There was a cyclical squeak, metal against metal. It turned out to be the screw that holds the drum paddle to the drum. It had worked itself loose and was scraping against the inside wall of the dryer. Remove the front door lift the top, and tighten 'er up. Hope that helps.
Nov 19, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
The paddle came off inside my Neptune Dryer
The screws for the paddle can be accessed by removing the small back panel. If they are stripped out you will need a new paddle.
Jun 07, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
942 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
