Question about Car Audio & Video
How to wire a vintage pioneer supertuner kp-500
I need to know wich wires go to what I have 4 wires red black green and gray. so red must be hot ,black to ground that leaves gray and green for speakers, and what black as a commen/ground ? and how many amp fuse?
  • 55 Answers
THAT IS AN OLD RADIO....RED POWER .... HARD TO SAY ABOUT AMPS LOOK ON THE RADIO IT MAY SAY TOTAL AMPS....I WOULD SAY (APX 5 AMP) START WITH THAT .
BLACK .......YES GROUND FOR THE POWER ...AND ALSO FOR THE GROUND FOR THE 2 SPEAKERS
SO .....GRAY&BLACK SAY LEFT SPEAKER
AND....GREEN&BLACK SAY IS YOUR RIGHT SPEAKER IT EASY GOOD LUCK
Posted on Feb 21, 2009
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
Need wiring diagram for pioneer supertuner DEH-405
Download manual from Pioneer website. Yellow is b+, red is acc, black is chassi ground. Green, brown ,gray and white wires are color paired for speakers. Blue wire is amp remote turn on .Hope this helps
Nov 01, 2009 | Pioneer DEH-1600 CD Player
Pioneer Kp-500 wiring red black gray green Red hot black common for speakers green 1 channel gray 2 channel Will play using radio chasis grounded should the black be grounded to the vehicle?
Hi and welcome to FixYa,
My compliments on the KP-500.
The black wire serves as common/return for the green/gray speaker wires. Yes, the black wire should also be grounded to the vehicle as it is the power ground and is tied to the chassis/body of the stereo.
Good luck and thank you for asking FixYa.
Oct 16, 2009 | OEM Systems Car Audio & Video
Having trouble hooking up the pioneer deh1700. the colors dont match with the vehicle its a 92 chevy lumina
" I AM NOT A PROFESSIONAL NOR AM I ACTING SUCH, I am only stating what I have done to solve "this" kind of problem.
First look on the original stereo from the Lumina and look for a wire digram to see the color coded wires. If you see this match with the list below, if you do not see this... after removing the stereo, With a test light or multi-metor look for a good ground to place the - clip or - probe. then look for a red wire. place the + end or the test light into the plug. if it light up that is the constant + [hot] wire. then with the ignition ON, place the light probe in to the next socket till you find another hot wire. turn the key OFF and see if the light shuts off. when you find this wire it is your ACC. the power antenna on my Honda is yellow/white I do not know the factory color for yours maybe blue, i don't know. to locate your speaker wires...... generally same colors [ brown, brown/black yellow, yellow/red and such]. you can take the batt pack out of your cordless drill and "TAP" the wires to the + and - of the batt pack. {hold the white to the + side and tap the white with black stripe to the - side...the speaker will make a popping sound. log all the colors with the location. You should have this....2 speakers should have 4 wires, 4 speakers - 8 wires If you do not have the amount stated then you have a common ground system and your - is grounded to the chasis [body/frame] and you will have one + wire for each speaker.
" just in case " the wire diagram for the Pioneer DEH 1700 is as fallows...
Black -- GROUND [-]
Yellow -- 12V constant [+]
Red -- 12V ACC [key on + only]
Blue -- Power Antenna
White -- left front +
White/black -- left front -
Grey -- Right front +
Grey/black -- Right front -
Green -- Left rear +
Green/black -- Left rear -
Violet [purple] -- Right rear +
Violet -- Right rear -
Aug 14, 2009 | Pioneer DEH-1700 CD Player
I dont know wich wire is for what for Pioneer DEH-P2000, i need a wiring diagram or manual
black ground red accessory (KEY) yellow memory constant power,blue is remote,orange is for the dimmer,green with black is left rear neg.and green is positive,violet black is right rear negative and violet is positive,white is left front positive and white with black is negative,gray black is right front negative and gray is positive
Jun 14, 2009 | Pioneer DEH-P2000 CD Player
How do i install a pioneer supertuner deh-1700 into a 1992 chevy corsica?
Black ground Red accessory (keyed) Yellow memory constant power,Blue is remote,Orange is for the dimmer,green with black is Left Lear negative.and green is positive,violet black is Right Rear negative and Violet is positive,white is Left Front positive as for white with black is negative,gray black is Right Front negative and gray is positive
Jun 08, 2009 | Pioneer DEH-1700 CD Player
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
PIONEER SUPERTUNER 3 KEH-P4200
tdohnke-So you need a wiring diagram,well lets see what we got
red-accessory-12volt key switched
orange-12volt constant-memory
black-ground
white-left front speaker-positive
white with black stripe-left front speaker negative
grey-right front speaker-pos.-
grey w/black stripe-right front-neg.
green-left rear-pos.
green w/black stripe-left rear-neg
purple-right rear-pos.
purple w/black stripe-right rear-neg.
blue- remote turn on
orange w/white stripe-dimmer-optional
Try out this diagram,they are pretty much all the same now,if I missed any let me know. cooltek Mar,4/08
Mar 04, 2008 | Audio Players & Recorders
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Pioneer SuperTuner III D wiring installation diagram which is wire is the ground
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis. Now go to http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html Register, and download your manuals. Problem solved.
Sep 01, 2007 | Pioneer DEH-P690UB CD Player
Car Audio & Video Logo
998 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
