Question about GE Profile JTP56 Electric Double Oven
Ge oven bake button does not work
I have ge JTP20 electric wall oven. When i push the bake key nothing happens. All the other keys work. i put in a new electronic control assembly, but the bake key still did not work. the baking element in the bottom of the oven works, because when i turn it on to self clean, it gets hot and the cleaning cycle works. I'm thinking that maybe something is wrong with the keypad? Should I try replacing it?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
By process of elimination and the description in your post, the keypad would be most likely. Additionally, there should be some error messages/display/code if the baking element is not working, thermal sensor is out or anything non-functional. The electronic control assembly simply does not sense that there was an input from the bake key, hence bake key faulty. Since it is one unit, pls replace the keypad.
Good luck and thank you for using FixYa.
Posted on Feb 21, 2009
  • GE Master
  • 19,396 Answers
Check if there is a fuse for the baking element.
  • Ginko
    Ginko Feb 21, 2009
    If it is the fuse, both elements will not work, and wont do self cleaning, therefore is not a fuse.
    If the Element is fine and heats up on self cleaning this restrict the problem to the control board, or the control panel. Replace the control assembly.
    You find parts for your appliance here.
    President:
  • 2,653 Answers
I would. There aren't that many other components that it could be and you can always just return the part if it isn't the problem.
I got an F7 error code and now the display is blanked out. JTP20 series wall oven
F7 Stuck Button
1. Function pad button stuck or
2. Bad clock. Try to free stuck button or
3. Replace Electronic Range Control (ERC).
Nov 25, 2009 | GE JTP20 Electric Single Oven
Convection oven burns most things GE electric. Is there some way to turn off the fan
Don't press the convection bake key before entering your oven temp,just push the bake key first then set temp and then start.If this doesn't help GE help center is awesome @ 1-800-626-2000
Nov 22, 2009 | GE Ovens
GE Wall Oven JKP13GOTBB Touchpad is "too sensitive"??
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
Aug 12, 2009 | GE JTP45 Electric Double Oven
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE Wall Oven JKP70 Locks and reads F9
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
Dec 29, 2008 | GE JTP20 Electric Single Oven
GE PROFILE MODEL JTP18WOAZWW
try fix at  http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me.
Jun 09, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
187 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
