Question about Sony KDF-E60A20 60 in. LCD HDTV
Were is the lamp driver located on the sony model number kdf-e60a20?
Were is the lamp driver located on the sony model kdfe60a20
Posted on Feb 22, 2011
My Sony KDF-E60A20 tv is not working this morning my lamp indicator was flashing is this a problem i can fix myself or is a service technician needed?
you can fix by replaced your tv lamp only.mostly lamp number menstion on top side. if not found then tell service center only model number of your tv and get your Lamp. Lamp replacement way menstion in Lamp user manual.
Oct 19, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
My sony television model kdf-e60a20 goes blank with no picture or sound for 45 seconds and then comes back on periodically during viewing.
Time to replace lamp as existing lamp is reaching to end of its working life and causing problem.
Lamp replacement procedure is easy and written in user manual.
Sep 04, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
While tv is on, at times screen just blacks out ...then comes on again.....audio remains but picture fades in and out....often
Replace lamp in tv because symptom shows lamp is near to end of its working hours life and causing that problem.
If lamp has not been replaced in tv in last 2-3 years, its time to replace it to solve the issue.
Thanks.
Aug 29, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp for sony lcd projection tv model # kdf-e60a20 located in the back?
To replace the lamp go to link below then click on operating instructions. then go to page 76. It will tell you how to change lamp.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDFE60A20
Dec 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60 model kdf-e60a20 wega
is the led blinking anything? When was the last time you replaced the lamp? A bad lamp can cause this kind of problem.
Dec 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the lamp on Sony LCD Model No. KDF-E60A20 located in back of TV
There are two thumb screws at lower corners of TV, lose them and take off lower front panel of TV, there you will see lamp cover, unscrew and remove it, lamp is in front of you.
Lamp replacement procedure is written in user manual, click Sony Support to download user manual copy of KDF-E60A20 if required.
Oct 19, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Where is the thermal fuse locates in the sony KDF-e60A20?
Hi, the thermal fuse i located right next to the lamp is actually mounted on the lamp casing, deep inside the tv, you will need to disassemble the tv in order for you to get to it, if don't have any skill is better that you call the repairman and you are looking at $250.00 repair.
good luck
Jun 22, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
May 07, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
265 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
