Question about Abit TH7 Motherboard
Motherboard is not recognizing my hard drive during boot process
My motherboard is not recognizing my hard drive during boot process when plugged into the IDE 1 port. Recognizes it when plugged into IDE 2 port though. Any solutions for a possibly faulty IDE 1 PORT?
  • Anonymous May 22, 2009
    yes i have a problem
    President:
  • 2,653 Answers
It's probably the jumper settings on the hard drive. You can try cable select but I usually prefer just setting it as a master. Let me know if that works.
Posted on Feb 21, 2009
Disk boot failure
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Foxconn G31MV-K Motherboard
I am attemping to load linux, ubuntu, on to a dell with an intel board, it is not accepting the hard drive during install of the os, i was wondering if there was was mother board reason, a jumper fix?
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
if its not accepting your hard drive test the leads that attach from motherboard to hard drive make sure they are securely seated with no dust built up or replace them they could be faulty
hope this helps
Aug 07, 2011 | Intel D865GBF Motherboard
Hitachi sata 120 gb hard disk lock & password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also if this is a desktop computer
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 29, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
The drives are not recognized in the post. It will not go to bios. the motherboard is a m2n78-la
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions, DE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electrical power and data to travel through every working device its and have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS
hope this will help
Jul 26, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Hard drive locked by unknown pass word
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased:
. Hope this helps
Jun 28, 2011 | Western Digital (WD3200JS) 320 GB Hard...
Wd3200bevt my hard drive suddenly there was a password. what is his password? or what to do for harrdisk be re-used?
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. hope this helps
Jun 11, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
Have a FIC K8-800T Motherboard. Works fine with 1 SATA drive. Does not recognize second SATA Drive if drive is very large
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
Apr 20, 2011 | FIC K8-800T Motherboard
When i start it say Reboot and select proper boot device or intsert boot media in selected boot device
Most probably the cause is one of the following:
  • No OS installed.
  • Hard-drive connection is loose.
  • Windows is corrupt.
  • Harddrive jumper is not figured correctly (in case of IDE PATA) or it may have malfunctioned.
Disconnect the PC from the mains supply, remove the cover on the system and check for any loose cable connections of hard drive.
Check inside the BIOS whether the drive is listed and as the first boot device in Boot Order tab.
Note: During inspection take care to avoid touching any board component unnecessarily. Also avoid using force.
Dec 17, 2009 | Intel D845GVFN Motherboard
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Abit TH7 Motherboard Logo
78 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
