Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Trouble setting up VGA cable to watch movies from my computer on my TV?
  • 8,596 Answers
First, make sure the VGA cable is plugged into the AV6 slot on the back of the TV.
You will have to go into your computer, and click Start --> Control Panel --> Appearances and Themes --> Display --> Settings and change the screen resolution to 800 x 600 first.
Then go into the program for your Graphics Card and change the screen resolution to 800 x 600 with a 60Hz Refresh Rate - sinc ethis will most likely be a change for you, your computer screen will seem to "flash" a bit - your eyes will adjust as you become used to this.
The other resolutions that work will be the following, but the 60 Hz refresh rate is the key:
Supported Display Resolution•Computer formats: 640 x 48060Hz, 800 x 600 60Hz, 1024 x768 60Hz, 1280 x 720 60Hz•
Posted on Feb 21, 2009
Where do you watch movie on a computer
The DV10 lets you connect 3 types video cables. VGA, Component, or RCA composite. Look at your computer to see what video outputs it provides.
If you Google VGA cable, Component, or RCA composite, you'll see what these cables look like.
May 02, 2014 | Optoma MovieTime DV10 Multimedia Projector
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
Want to put computer movie on tv
Sort of depends on the TV connections? Your laptop specs list a VGA prot and a HDMI port. What does the TV have? HDMI? VGA? Do you have the cables? Does your TV have a USB port? If so, you can put the Movie on USB. Does your TV have a Wireless Adapter? If so, you can add/share your videos from a Home Network. There are option but without the TV info, I can't give a informed solution.
Jan 11, 2013 | Gateway NV5378u Notebook
What cable do i need to buy for my laptop when i want to watch a movie thats on my laptop through my tv? i have a Acer aspire 4315
If your tv has a VGA socket suitable for a computer then all you require is to set your laptop resolution to suit your tv screen and a VGA plug to plug lead and you're watching video's.
Jan 03, 2011 | Acer Computers & Internet
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Watch movies from computer to tv
look on the back or sides of the unit. it should have a hdmi cable hookup, it will look like a monitor input, then you have to make sure you set the tv input to that. then you have to set your laptop to add another monitor to be able to use it.
Mar 20, 2009 | Philips 55PW9363 55" Rear Projection...
Need help watching a movie from laptopn to tv
What kind of help?
Connection?
  • if you have a S-Video connection use it (remember to use another cable for audio)
  • If your TV set has a VGA connection use it (always + audio cable)
  • If HDMI connection available use it
OR look for a special connector matching PC VGA port with RF modulated antenna signal on TV set or composite input. Here some detail
Jan 30, 2009 | HP Compaq nc6000 Notebook
Hooking computer up to tv to watch movie
Purchase a vga cable and hook it up to the computer and then to the tv
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
580 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
