HP DV5000 shuts down if not plugged in...
Bought a new battery and still shuts completely off as soon as you unplug the power cable. I am guessing this is probably a hardware issue and can't be fixed but if there is anything anyone can thing of it would be much appreciated...
    President:
  • 2,653 Answers
You're right it's a hardware problem. HP has just extended their warranty support for many of the DV laptops. You can check yours out here:
http://www13.itrc.hp.com/service/ewarranty/warrantyInput.do?admit=109447627+1235178372960+28353475
Posted on Feb 21, 2009
After pressing the power button, my HP dv7-1129 laptop only stays on for about 2 seconds and then shuts off. I completely replaced the DC cable and now it receives power, but it does not boot up. What is...
try taking the battery out, unplug the DC cable and hold down the power button for 30 seconds this will get rid of the static on the motherboard which could cause the problem.
After you have done this put the battery back in, then the DC cable then try to turn it on.
If not it could be your battery because you are getting an indication that you are receiving power, try taking the battery out and just plugging in the power cable.
Hope this solves the problem.
Jul 13, 2011 | HP Pavilion dv7-1129wm Notebook
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
How do i access the processor fan for hp pavilion dv5000 because it gets extremely hot in the top right corner, then shuts down. and the fan only runs for like 2 minutes every 30 minutes
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
AND
With the ear bud clean the vents of the fan and check whether it is happening again. And if it is happening again do the bios update of the computer from the hp.com website and check.
Oct 28, 2009 | HP Computers & Internet
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
IPAQ hx 2110
You may need to purchase a new internal battery
Feb 04, 2009 | HP iPAQ H2200 Pocket PC
PC turns off when I unplug it.
Not an expert but i suggest you view power options in control panel and check settings when to power down....
Hope it helps
Oct 29, 2008 | HP Compaq Presario V2000 Notebook
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Computers & Internet Logo
319 people viewed this question
David Payne
David Payne
