Question about Toshiba Satellite A135 Notebook
Cant activate wireless capability on my toshiba satellite L40-139
When i turn on the wireless from the switch at the front of my laptop an icon at the top of my screen shows the same thing as when i turn off the switch. When i try to connect to a wireless network it says to turn on the switch at the front. Is there anything I can do myself to fix this or will I have to get it repaired professionally?
  • RescueTechLA
    RescueTechLA May 11, 2010
    You can check to see if the wireless is enabled in the bios screen. Did the wireless work before?
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
Turning on wireless
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
On some laptops there will be a button just above the keyboard or on the side or in front of the laptop..
Jun 09, 2012 | Toshiba P000413700 QOSIMO G10 G15 SERIES...
How could you know if wireless switch is on
Normally somewhere on the laptop there will be a light that emits to show that the wireless is on.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
On some laptops there might be a button that you press above the keyboard or on the sides that turn the wireless on or off.
May 31, 2012 | Samsung N150 Series Netbook
Where can i find wifi switch on my acer aspire 5570 ?
May 27, 2012 | Acer Aspire 5500 5570-2609 Laptop
Won't find wireless connection
Did you turn the wireless switch on? Normally there is a switch either on the sides or the front of the laptop that you have to turn on. Sometimes it is a button at the top of the keyboard.
May 21, 2012 | Packard Bell Easy One Silver 2101 Notebook
How do I turn on the Wireless Adapter on a Lenovo W500?
Look on both sides and in front of the laptop for the switch. Once you turn the switch on you can also control the wireless by keystrokes. Normally you Press and Hold the FN function key located at the lower left portion of the keyboard then hit the correct key F1 thru F12 that controls the wireless. The correct key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal )))) on it. When you toggle the wireless by keystrokes the display screen might show Wireless On or Wireless Off.
May 02, 2012 | Lenovo ThinkPad W500 (406236U) PC Notebook
Turn on wireless
There might be a wireless switch located on either side of the laptop or at the front of the laptop. If so flip the switch. Also there might be a combination of keystrokes that toggles the wireless on and off. Normally you would have to hit the FN Function key + another key (F1 thru F12) to toggle the wireless. The correct F1 thru F12 key will probably have the wireless icon )))) on it. Press and Hold the FN key then hit the correct F1 thru F12 key that controls the wireless. When you do it your lcd screen might show Wireless On or Wireless Off as you press the keys.
Mar 31, 2012 | Computers & Internet
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
Dec 20, 2010 | Computers & Internet
Wireless switch on the front of the lap top wont turn the wireles on. can i turn the wireless on without using this switch? laptop is VGN-FW21Z
Depending on the version of your operating system, you can right click on the icon in the bottom right that represents your wireless connection. Then select "enable". This should turn your wireless on. If this doesn't work, you can do the same thing through the control panel if you click on network places and go to the wireless section.
Oct 30, 2009 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
942 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
