Question about Hoover F5900-900 Upright Steam Vacuum
My Hoover Steamvac- the brushes are not rotating neither L or H
No matter which setting the brushes aren't turning. Is there a belt that turns them? The guide I have doesn't provide that information. Please let me know.
My hoover steamvac the brushes are not turning what makes the blue triangle that the brush attachement fits to move?
Posted on Feb 26, 2009
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
How to change the belt?
There is no belt on a Hoover SteamVac. The brushes are rotated by an air driven turbine. If the brushes aren't spinning, you most likely need to replace the turbine assembly.
Jul 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac gold-belt?
Do you mean the brushes will not spin? the most likely cause is the bearings have seized, it will need repair or replacement. check also the brush speed knob. when on, and handle tilted the brushes should rotate. There is no belt.
Sep 16, 2008 | Hoover F5886-900 Steam Vacuum
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
F6212-900 / F6215-900 SteamVac Agility
There is no belt, sounds like the turbine is bad and will have to replaced.
Nov 27, 2006 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F5900-900 Upright Steam Vacuum Logo
250 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
