Question about Cooktops
Lost manual for 36" 6 burner Electrolux Icon cooktop. I need to download and print another.
  • 63 Answers
Hi my name is mark, try the website www.managemyhome.com go to home manager then scoll down to owners manuals hope that helps.thanks for your question.
Posted on Mar 11, 2009
My Electrolux stove top piezo ignition won't stop clicking how do I make it stop
Hello Jan, thank you for your inquiry!
From what you have described your Electrolux cooktop will not stop clicking. This could be an issue with your burner or gas connection. I would suggest having a professional technician out to look over the cooktop as well as disconnecting your gas connection. I hope this information is helpful to you. -Matt
Mar 08, 2016 | Electrolux 36 in. Designer Series...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
Error codes EO 21
Good Morning sisutl, thank you for your question!
Could the error code possibly be E-21? If so, this error is commonly referred to an issue with the oven thermal sensor. Typically, the over thermal sensor is in the open position. A professional would need to verify continuity of sensor harness and connections. Depending on an accurate diagnosis the part may need replacing. I hope this information help to some degree.
Sep 06, 2013 | Electrolux ICON Designer Series E36IC80ISS...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
My electrolux iduction cook top sends error across the whole bord when I put anythng on the inductoin burner
You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by flipping the circuit breaker off and back on. If the error code does not clear, then the unit more than likely can be experiencing an issue with the EOC and user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
Sep 11, 2012 | Electrolux 36" Electric Hybrid Induction...
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
The ignition keeps ticking on my new electrolux cooktop after it's lit. This affects all burners. It did not do it when first installed, started a few months later. Affects all burners, sometimes it stops...
the igniter switch is sticking from burned on grease, or other residue. if you know how to get to the switch. you can soray some wd-40 right on the switch let it set for a little while.30 min. then rotate the knob back and forth a few times and it should unstick...if not call a serviceman. your stove is under warranty.....goodday.
Nov 15, 2009 | Electrolux 36 in. Designer Series...
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
Oct 10, 2008 | Kenmore 42800 Stainless SteelCooktop
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
