Question about Amana Refrigerators
My amana model #SXDE27NE says i need to clean the coi. How do i do this?
  • Amana Master
  • 2,651 Answers
Remove the lower kickplate, and youll find the "coils" under there, with a refrigeration coil brush youll be able to vaccuum all the dust out from there
Posted on Feb 21, 2009
Drain line on rheem raka037jaj cenyral air unit not draining and cois freeze up
Hello, coils will freeze either to low airflow or low refrigeramt charge. Make sure filter, blower wheel and evaporator coil are clean. If they appear clean there is a low refrigerant charge.
Jun 06, 2012 | Heating & Cooling
Amana dishwasher Manual
Amana has many of its appliance manuals on their support site: . However, I can't find the above model number.
I found models ADU6000DB and ADU6000DWW. The manuals for these have not been uploaded to Amana's site. I also found the Whirlpool models DU6000XR* and DU6000 with the manual here: . There is also a Amana Master Clean, DU6000BR, with the manual here: .
I hope that your dishwasher is similar enough that the manuals above help you use your appliance.
Mar 19, 2012 | Dishwashers
I need a manual for an Amana Glass Top range 5yrs old , self-cleaning, large oven
You need the model number of the range to get the correct manual. Most Amana manuals are available here: . The model number is on the frame of the range behind the storage drawer. Often you need a flashlight and fairly good vision to read off the characters on the plaque.
If you add a comment with the model number, I'll check for the direct link to the manual.
I hope this helps.
Oct 21, 2011 | Amana Kitchen Ranges
The wall between the side by side refrigerator and freezer is extremely hot to the touch. Model # HSS25IFMWW
hot wallson a fridge could be 2 things first check in the bottom bak if the condenser fan is working 2 clean the condenser coi with a long brush, you will see results in a few min
Sep 04, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
CoI need a manual for model SNPRH-0807
It appears that the numbers you posted are for an power adapter for the HP A640 model printer.
Please look on the rear or bottom of your printer and verify the model number.
If the information I have given you is correct, please go to the HP link below for downloading the latest printer drivers and software as well as the manual for the A640 printer.
Aug 25, 2011 | Office Equipment & Supplies
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Toshiba 2060
1. First of all power off the machine
2. Switch on the machine while pressing 'Print+8' keys
3. Press help button
4. It will show the current code on display
5. Press clear/stop button & then press energy saver button.
6. If another codes exist it ill show those codes also, Repeat step 5 to clear that codes also.
7. Now enter new four digit code & press energy saver button to save the code.
8. Restart the machine
E may, vao day coi co con nho nay ngon lam unE may, vao day coi co con nho nay ngon lam
Jul 27, 2008 | Toshiba 2060 Copier
Refrigerators Logo
103 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
