Question about Vizio L37 Television
I pressed rgb on the remote-now i cant get out of that mode
Pressed rgb on my remote-now tv broke
  • 99 Answers
Have you tried changing the TV to another input? Try Press "TV" at the top then press "TV" near the bottom or try pressing the "INPUT" button on the TV itself until you get to TV. RGB is just another input for the TV, just like DVD or HDMI or VCR, but it is the plug in the back for a computer monitor. Yes, if you'd like to hook up your computer to your TV you can through this plug, it looks like a (most likely blue) with 3 rows of holes/pins that you can plug another RGB cable into your computer and have the biggest computer monitor on the block! haha Although, if you have a PLASMA TV (not LCD) you can't use a computer for long (no more than 15 mins) because PLASMA TV's have a tendancy to "burn-in" very easy and it is sometimes not fixable. You'll have a ghost image of any stationary image that is on the screen for too long. That goes the same for any news channels with a "ticker tape" near the outside edge that is on the screen the whole time. If you have LCD, no worries! They're designed just for that problem to never happen. Hope this helps.
Posted on Mar 02, 2009
How do i get a picture from laptop to tv i have connected r.g.b lead
I am not familiar with your tv but the normal process is to change press the button combinations on your laptop so it is outputing the picture and then change the tv input to RGB. (Most laptops use function and F7 to activate LCD output & Input button on TV remote to change to RGB mode.)
Check the VGA cable is fully connected at both ends.
Hope this helps.
Jan 31, 2012 | Acer Computers & Internet
I have a Plus UP 1100 and the remote control was lost. How can I switch from video mode to computer mode manually?
you can select the RGB mode (computer mode) by the following without remote.
1. press the menu button
2. with up arrow or down arrow select source menu and press enter up arrow or down arrow to select RGB AUTO and press enter
4. press menu button to exit menu.
Jan 27, 2011 | PLUS Vision Corp. UP-1100 Multimedia...
I have an RGB port on my visio, but my remote does not have any buttons to get to RGB mode, I have all the others like HDMI AV and component... How do i get to RGB mode if it is not on my remote. going to...
There is a video/input/source buuton on the side of tv. Push it and all inputs will be there use volume control to move the highlighted input when you get to the one you want push input/video/source it will change the channel
Dec 13, 2010 | Vizio Televison & Video
AV2 sign won't go away when playing dvd
Press Info/ Display button on TV remote, on-screen display will disappear.
Jan 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
Jan 02, 2010 | Vizio VX37L Television
Service menu codes
Panasonic TH-42PZ80U Enter Service Mode InstructionsWith TV on, press and hold the volume down button on the front of the TV, and press info three times on the remote. Select Category Instructions1 and 2 Change Data Instructionsvolume up and down Exit Service Mode Instructionspower down Menu Categorywb adj Menu Itemsrgb cut rgb drive all cut all drive -->do not use these unless you need to match ywo displays side by side.
Apr 16, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Cant see dvds on my emerson tv
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
Feb 13, 2009 | Emerson EWF2704 TV
Video mode
do you meen by video mode that it is in an external mode via a scart lead. if so does it operate ok if the external inputs to the tv are removed ie only leave the aerial lead plugged in
Oct 30, 2008 | Sanyo DS13204 TV
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
Vizio L37 Television Logo
116 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
