Heater works fine. But we have a wood fire heater that runs almost 24/7 over winter and id like to beable to curculate the warm are around the house with the Breamear TH3 fan (no gas heating) how do I set this up?
I think you could do this if you had the Spectrolink (SCC) controller. see http://www.renovateforum.com/f221/braemar-installation-manual-th3-th4-th5-thm5-thm6-105067/
SOURCE: Rediant Hot Water Heater Won't Shut Off!
I've got the same problem this morning, any helpers out there?
SOURCE: Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
SOURCE: Heater works, but only on Emergency Mode
It sounds like you have a "setback thermostat" A control intended to increase efficiency by allowing the fan to run for an adjustable amount of time after the heater turns off, whether the heater is electric or part of a heat pump. If the "setback" time is too long, the element will cool off and the fan will blow cold air. Try and locate the instructions for the thermostat and see if the "fan run time after heat turn off" is adjustable and reduce it by half. Most emergency heat circuits bypass control circuits (its an emergency, you know), and require manual control.
SOURCE: pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
