Question about Frigidaire GLER341A Electric Dryer
Squealing dryer every time I turn on my frigidaire crown heavy duty series dryer it has a very loud squeal until it gets warm. how do I stop this from happening
  • Anonymous May 21, 2009
    My dryer squeals from a point in the center of the back. Looks like a ball bearing there. Can I oil it?
  • Frigidaire Master
  • 3,361 Answers
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Posted on Feb 21, 2009
My frigidare heavy duty crown series gas dryer is n0t heating and barely able to dry my clothes--what could be the problem and how can i fix it
Hello Chuck, thanks for your inquiry
Based off the information you have provided I have identified a few possibilities as to why your dryer is not heating could be the element, thermostat, or control panel. Each component controls the heat within your dryer and if one goes out it is possible that can cause the rest to not function properly. To accurately find out the reason to why your dryer is not heating I would recommend having a professional come out. Hopefully this is helpful. -Matt
Sep 28, 2014 | Frigidaire Dryers
Loud squeal from Frigidaire electric dryer, tumbler slipping, then smoke and blown breaker
Sounds like the bearing on the motor, had this problem with my two at the same time replaced the bearing and they are both ok now.
also check the back bearing on the machine usually hidden by a plastic cover thats where the squealing comes from they are easy to replace and don't cost much all it is ,is a bit of brass which doesn't last long.
hope this helps.
puggy
Jan 13, 2014 | Frigidaire Dryers
Hyundai accent squealing very loud
You need to replace the belt.
Once a belt gets glazed it will slip no matter how tight it is.
Jan 17, 2013 | 2000 Hyundai Accent
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
My dryer is squealing very loud when it is on.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 07, 2010 | Frigidaire Dryers
I get a loud squeal from the fan area only when
It could be a pulley. Best way to tell is to remove the belt and turn each pulley one at a time and see if you can either feel one not turning freely or try and duplicate the squeal. Keep in mind there is no load on the pulley without the belt on it so it might not be as pronouce as it would be with the belt on.
Jan 30, 2010 | 1996 Ford Crown Victoria
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 12, 2009 | Dryers
Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Aug 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
815 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
