Question about Alpine CDA-7940
Need pinout for Alpine CDA-7940 head unit
I got this deck with a car that had the Alpine CDA-7940 in it with no wiring plug attached.  So I was thinking I could build my own if I knew what each connector pin served.  (i.e. battery, ignition, remote, illumination, and speaker (+) and (-) leads.  I imagine any slightly newer CDA deck may have a very similar pinout for the main harness.  Can anyone email me a resource with the exact info?  Or does anyone know?  I would appreciate it a lot!
Thanks.
Ben Moore
  • 21 Answers
Facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Posted on May 19, 2009
I am suddenly unable to adjust the base, treble, volume, etc on my Alpine CDA-7940 stereo. Is there a lock or setting for this?
press the mode button, which is the audio knob repeatedly to choose the desired mode and rotate the knob until desired sound is obtained. as you press the mode button, the option will go from these followings: volume, bass, treble, balance, fade
Jan 13, 2015 | Alpine CDA-7940
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Nov 28, 2012 | Car Audio & Video
What does it mean when the rear of a head unit is
you probably have a bad output ic inside the deck.
Jun 16, 2010 | Alpine CDA-9811 CD Player
Cda 9883 - no sound
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
Feb 20, 2010 | Alpine CDA-9883 CD Player
Connecting the speakers to the Alpine CDA-7940
Typically the orange wire in a car stereo are connected to the + always on ( it's usually for back up memoru). ordinary AWG # 18 flat cord will be sufficient for the purpose
Jun 26, 2009 | Alpine CDA-7940
Need Pinout
no - the harness is $17 or less.
Even Metra makes one (pictired above)
In my shop I charge $17 for the metra plug.
eBay it.
Metra part# AL16-0001 or al2x8-0001
CLICK HERE for an eBay auction for an original ALPINE plug. $30
CLICK HERE for an eBay auction for a $2 (shipped) one.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 29, 2009 | Alpine CDA-9831 CD Player
Alpine 9884 and ipod hook up
No. This unit is designed to choose songs through the deck itself
Oct 10, 2008 | Alpine CDA-9884 Car CD/ MP3 Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
Alpine CDA-7840
Some 4-Runners have a factory system that uses a separate amplifier to power the rear speakers. In this case you need to activate the amplifier using the blue/white remote output from your Alpine deck. It sounds like the wire that activates the amplifier is currently attached to the deck's blue "power antenna" output, so that the amplifier is only on when the tuner is selected. Disconnect whatever is attached to the blue wire behind the deck, and attach it to the blue/white wire instead. That should solve the problem.
Jun 09, 2007 | Alpine CDA-7840
Alpine CDA-7940 Logo
501 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
